A4 TDI SE outside temp?
Dan TheMan Welburn Dec 7, 2012
  1. Hi all my enternal temp display on my dash has always been a little off, for example when its been snowing the last few days altho the real temp has been -3 my dash display varies from being 1 when first started then goes up during driving and has ended up showing 8.5 :S is there a sensor which controls this? also is it cost effective to change and where is it located? thanks
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    It's right in front of the rad you can't miss it
  3. demus
    demus Fire in the hole..
    355
    19
    Is the connection on thew said sensor ok??, a bit of extra resistance there will sod up the reading..
  4. I'll have a proper look in the morning, cheers fellas
