a4 tdi,is this right? temp gauge question.
vw754 Nov 20, 2006
  1. vw754
    vw754 vorsprung Durch Technik
    2,347
    58
    :sos: A4 TDI 130BHP AWX engine
    Ive noticed the other day,engine was running and i put the heaters on and temp gauge started going down very slowly(quicker if heaters on full boost) is this right or is the gauge suppose to stay at half way?
  2. SteveS
    SteveS S6 avant
    691
    the heater takes its heat from the engine via the cooling system so when you have the heater on high you are taking heat away from the engine and blowing it into the car so its fairly normal for it to have a cooling effect on the engine. hope this helps!
  3. sniperlover
    sniperlover Member
    199
    Thats correct when the heating is on full blast the temperature of the engine drops.Well i remember when i had a ford fiesta,the engine is always over heating so i put the heating on full blast and that will cool the engine down till i get it fix.Some old trick.:thumbsup:
  4. Marko
    Marko Member
    202
    I didn't notice it much with my petrol A4 but I have done with the 1.9TDi 130 I have. I rather think it's normal. Plus I find it takes much longer to warm up in this weather too.
  5. VennyQuattro
    VennyQuattro Member
    52
    The heater matrix runs off the cars cooling system, so it will have an effect, however I haven't noticed much of reaction on the temperature guage in most modern cars.
    The idea is the thermostat regulates the engine temperature at the 'norm' so I would expect it to compensate.
    It doesn't sound like much to worry about though.
