A4 TDI 130bhp no power
Bonso Nov 12, 2004
  1. Bonso
    Bonso New Member
    Hello there,
    Have a problem which started last night, everytime I change gear my car loses power for about 1 or 2 secs then takes off like a rocket.
    Any suggestions on what this might be?
    Regards
    Bonso
  2. imported_Hingy
    imported_Hingy Guest
    At what rpm are you changing gear?
  3. jojo
    28,944
    3,598
    [ QUOTE ]
    Bonso said:
    Hello there,
    Regards
    Bonso
    [/ QUOTE ]
    First of all, Welcome to the Forum Bonso /ubbthreads/images/graemlins/beerchug.gif, how olds the car and what mileage?
  4. Bonso
    Bonso New Member
    changing gear at around 1500 to 2000rpm, car is july 2001 and 102,000 miles. Full service history.
    Regards
    Bonso
  5. imported_Hingy
    Hi Bonso, It may just be because the revs are too low after the gearchange, so you've dropped into a low torque area. Also, you'll get a fair amount of turbo lag after changing gear if you change that early. Unless I am foloowing some slow traffic, I will change up at anything between 3000 and 4500rpm, depending on how much of a hurry I am in. The engine then drops straight back into the powerband and turbo lag is almost undetectable.
    Believe it or not, it will be more economical to use more of the rev range when accelerating, as you are getting closer to the engine's more economical torque peak, as long as you change up when at your desired speed.
  6. Bonso
    Bonso New Member
    Do you think it might be the air flow meter as I have no power at all until the turbo kicks in?
  7. jojo
    28,944
    3,598
    102K miles, I take it you've done most if this yourself... sound like it could be the MAF sensor, which would be like **** throttle response an the turbo lag you are feeling, costs around £80 from your local stealer.
  8. Mcgough
    Mcgough Member
    846
    at worst mate you will have a new ECU like me
  9. my a4 has no power between 1000 and 1500 rpm, its always been like that though, soon as it hits 1500 rpm it launchs.
  10. imported_Macduff
    imported_Macduff Guest
    Try driving it as Hingy suggested. Then post the results.
    I know that ours is flat as a pancake at 1000-1500 and it's only 4 months old.
    Dave
  11. GregC
    GregC Member
    278
    [ QUOTE ]
    Bonso said:
    Changed MAF sensor everything fine for 3 weeks. Now once or twice a week everytime I change gear have no power for about 2 or 3 seconds (car feels like you put the brakes on and cars behind almost rear end me) then takes off but still not at full power rate. Have also noticed that if I lift off then reapply the car jerks as if its getting no fuel.
    [/ QUOTE ]
    You may wish to try some of the BMW forums - this kind of braking then accelerating hard seems to be an optional extra on some of their models (or is it just me...)
    [ QUOTE ]
    Bonso said:
    Any suggestions as my wife refuses to drive the car at the moment.
    [/ QUOTE ]
    Is this a bad thing... /ubbthreads/images/graemlins/devil.gif
    Greg
