A4 TDI 110bhp Recommended Aftermarket Air Filter / Induction Kit
CHR15 B5 Aug 10, 2010
  1. CHR15 B5
    CHR15 B5 New Member
    Hi Guys, New To The Forum, Ive Got A 98 A4 TDI 110, Im After Fitting A K&N Induction Kit, But Ive Read & Heard That Oiled Filters Cause Problems With The MAF, Could Any Of You Guys Recommend The Best Or A Good Non Oiled Induction Kit/Open Air Filter To Fit? Cheers:thumbsup:
  2. voteforpedro
    voteforpedro Member
    632
    I wouldn't recommend any. Paper filter FTW. The only ones I've heard good things about are the Carbonoi and the BMC CDA, both of which are expensive.
  3. cossie
    cossie Member
    79
    Hi, i fitted a K&N Induction Kit to my '96 A4 1.8T 20V over a year ago with no faults at all. I have heard of MAF problems due to oil but mine hasn't had any adverse effects. My car now has a nice sound to it now and when i come off the accelerator i can hear the recirculating valve which sounds like a mini dump valve! Hope this helps in some way.
  4. aragorn
    17,872
    686
    The standard paper filter will flow in excess of 500hp, and costs about 4 quid. Why change it?
    Spend your money elsewhere on something that will actaully make a difference.
  5. voteforpedro
    voteforpedro Member
    632
    Also, I don't know if it's the same on the TDi, but the area around the airbox on the 1.8T gets very, very hot. I wouldn't do it to mine as I suspect that it will do nothing but suck in hot air. Probably not too bad when moving, but pretty bad when idling.
  6. tdia4
    tdia4 TDIPOWARRR
    613
    I tried a open airfilter on my 1.9tdi because i had one laying around, had it on for all of a minute, they sound awful with one on.
