A4 T Sport engine swap issues
Oranoco Jan 7, 2011
  1. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    Some may remember I purchased a cheap A4 T Sport with the intention of fixing it and selling on for a nice profit. Unfortunately the cambelt failure that the AA man had diagnosed actually turned out to be a thrown rod. I ended up selling the car on to a mate of mine (who may have signed up on here).
    He obtained a replacement AEB from a Passat and we set about stripping the old dead motor from the bay.
    As it was out we fitted a new clutch kit and proceeded to fit the new engine. For the life of us we can't get the poxy thing back onto the box so we can bolt it. A couple of times we've been so close we could smell it but then just couldn't get the bolts in to secure it.
    Anybody offer any advise that's done a swap, we're both pretty competent but are about ready to call it a day and just buy a Vauxhall.
  2. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Are you 100% sure the clutch is in the centre? If it is just persuade it to go on.
  3. aragorn
    18,606
    871
    Its probably clutch alignment, as above!
    Hows the cylinder head on the engine with the thrown rod?
  4. Foxmeister
    Foxmeister Fired Up!
    1,785
    Yep, clutch likely. Did you use a clutch alignment tool, or homemade one even??? Once properly centred, some brute strength usually gets it straight on!
  5. ian52
    1,199
    When i did mine i lined it up by eye and from what i remember it went on the shaft ok but the last inch or so was a bit tighter and just needed a bit of foce to get it home.
  6. Foxmeister
    1,785
    Maybe best listen to this guy^^^^, he seems to know wot hes on about!!!!
  7. Oranoco
    3,998
    408
    Cheers guys, yes I did use a clutch alignment tool. Maybe I'm not being brutal enough with it.
    No idea in condition of the old head. We were going to strip the old unit down and see what could be salvaged. Feel sorry for whoever the engine came from though as it's obviously had a major service shortly before the car got totalled as the belts are all like new. Came complete with wiring harness, coil packs and ECU. Bit of a bargain at £350
  8. aragorn
    18,606
    871
    Let me know, because if its in good nick (ie not full of sludge) and cheap i'll have it.
  9. Oranoco
    3,998
    408
    I'll let you know mate :) Or Rather I'll get my mate to let you know as it's his car now after all
  10. murran
    murran Well-Known Member
    1,545
    39
    have you left the 'box in the car then? might be an idea the take the slave cylinder out of the box? it'll have extended and your figthing that too. also try rotating the engine a 1/4 turn and try wiggling it on again.
    you shouldnt have to fight it.... ive seen people smash the spigot bearing by being ignorant and using the bolts to pull it up the last 1/2 inch.
    alignment wise, theres three places around the edge of the pressure plate where you can see the friction plate inbetween the flywheel and pressure plate. stick your finger in and feel if the 3 spots all feel even. ie its in the middle.
  11. Oranoco
    3,998
    408
    Typical, after all that ball ache, today I popped in and the poxy thing almost fell into place. In just 2 hours the engine was in and 80% of the plumbing and wiring was completed. Sods law eh?
