A4 Sub
markcnash
Bristol
Before I start taking bits apart on my A4 2001 can someone tell me where I might find the standard amp & sub ?
if its a b6 a4
and if it has the bose system installed it will be in the right hand side cubbyhole
look for a big black plastic moulding with a tiny grey amplfier on it
I have found the sub which is under the parcel shelf facing into the boot, Should there be anything else ?
Ok Amp now found :idea: I have Replaced with 750w 3 way amp running rear speakers and two 10 inch subs in a box.
Much nicer clear sound and more bass than I would need. :music:
Hi,
am looking to do a simler setup on my audi a4 can you tell me what you did as for wiring amp!!! did you by pass old amp!and where did you get the remote feed ... does it thud when switch on!!
cheers mate.... Ole.t
852
