A4 SPRINGS?
vw754 Nov 5, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,347
    58
    Ive been told coil springs out of a A4 2.0 TDI (B7) will fit A4 1.9 TDI (B6) my car is standard A4 1.9 TDI (not even an se) the springs are from an S-line TDI, how low will my car sit with the s-line springs?
    Also what difference are springs from a s-line and from a sport ,are the the same height?
  2. jase0851
    jase0851 Member
    789
    should be 25mm lower. i thought the suspension was the same on s-line and sport
  3. arthurfuxake
    1,308
    S-Line is lower than sport.
  4. james0808
    james0808 Active Member
    3,548
    Not sure you want to go lower on the standard shocks.They are really ****.
  5. vw754
    2,347
    58
    can i use s-line springs on my standard shocks?
    do i need to replace/cut-short the bump stops?
    if sport is 25mm lower,how low is the s-line springs?
    finally will camber adjustments need to be made?
  6. james0808
    3,548
    I wouldnt use anything apart from standard springs with standard shocks.
    You can shorten the bumpstops for a little more clearance but if your dampers are too soft it will still bang on them.
    Not sure on the difference on the ride height.
    You should always get your camber checked when changing steering or suspension components.
