A4 Sline 2.0t se black exhaust tips ( HELP )
SNAKESASS Oct 10, 2013
  1. SNAKESASS
    SNAKESASS TT 2.0 TFSI
    50
    Wonder if anyone can help ,
    Ive got the standard exhaust with the black tips , there 80mm in diameter and are very short. Ive have searched the universe for some chrome tips to slot over the end but no luck. One option is to have them cut off and new stainless tips welded on. After spending nearly a grand on a new Vanos unit I'm a bit skint so has anyone got any suggestions.
    The exhaust is in excellent condition so I'm a little nervous about cutting and welding. Would prefer tips but just can't find the right size.
  2. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,687
    550
    Do what I did at the weekend mate. Wire wool and autosol will bring them up cleaner mate.
  3. JimmyH
    JimmyH Active Member
    374
    73
    Elbow grease works wonders :)
    las previously said, wire wool and a good metal polish.
  4. SNAKESASS
    50
    Thanks for the reply lads ,
    Just picked up some autosol form Halfords. Going to get stuck in before the Audi drivers awards on Saturday. Can't turn up with a dirty motor. You guys going ?
  5. Matt10160
    Matt10160 Active Member
    205
    29
    I bought some genuine audi tips that had been cut off on fleebay for a fiver, cut the rubbish ones off ass theyre only tack welded on, then welded the new ones on. All in cost was about £15.00
  6. ruairi83
    1,687
    550
    got any pictures mate
  7. Matt10160
    205
    29
    Havent got any before pics but they were just the turnt down style before
    these alegedly came off a pd170 A4
  8. SNAKESASS
    50
    They look the biz , I'm going to try elbow grease , wire wool and solvol autosol first. If that's a no go then a cut and weld it is. I presume you had to take the rear box off to do this. I will have to remove two if thats the case ?
  9. Matt10160
    205
    29
    Thanks they do make a noticeable difference, and Nope. took a dremel to the welds theyre smaller than a 5p peice ,pulled the old ones off, then welded the new ones on. It sounds easy and tbh... It is.
