A4 rear axle bushes.
a4avant Oct 10, 2005
  1. a4avant
    a4avant New Member
    12
    Has anyone changed the rear axle bushes on their A4 ? Any hints/tips or special tools required?
    Thanks, Paul T.
  2. a4avant
    a4avant New Member
    12
    Bushes now changed, an absolute doddle to change , totally transformed the handling.
  3. Broken Byzan
    13,235
    464
    Any special tools or owt needed mate??
  4. a4avant
    a4avant New Member
    12
    No fancy tools required, just some spanners and a hammer!!. Took about 2Hrs.
  5. Broken Byzan
    13,235
    464
    Thanks, gotta find me some bushes now then
  6. Broken Byzan
    13,235
    464
    Ok, i changed my bushes, although mine really didnt want to come out at all,lol, @£25 each it was well worth it, the difference is outstandidng.So much tighter and more precise.
    Tokk me an hour and a half to get the one done and half hour to do the other one from start to finish, the bloomin things are a soft alloy and fret in place.
    Tip for anyone doing this, make sure the bushes go in with the right orientation, the small cutout towards the antirollbar.
    HTH
  7. joost
    joost Active Member
    1,169
    Was considering Powerflex bushes on mine as seem to be getting a couple of clunks from the front again - been in to Audi for a couple of the front arms to be changed on the recall system already.
    Anyone know if the fronts are much harder to do? Apart from the obvious possible problems with the geometry etc?
  8. a4avant
    a4avant New Member
    12
    To remove the old bushes I burnt the rubber out of the middle then using a chissel , bent the inner side of the sleeve inwards to form a lip to give me something to hammer a large socket against to drive the sleeve out. (Poor description). Came out quite easily.
  9. joost
    joost Active Member
    1,169
    Cheers for that, may have a do at that sometime.
