A4 randomly showing traction and ABS lights
AudidriverA4 Apr 6, 2013
  1. AudidriverA4
    AudidriverA4 Member
    182
    Hi all,
    Just noticed over the last week my car has randomly starting displaying the TC and ABS lights as I'm driving along.
    Any ideas anyone what could be wrong with the car?
    Car is driving perfectly though :blink:
  2. Mollygoogle
    Mollygoogle Member
    227
    Have you got aftermarket HID's
  3. quattrojames
    14,050
    573
    Check the brake lights, it might be a faulty switch.
  4. AudidriverA4
    AudidriverA4 Member
    182
    No Hids's and brake lights are all working :uhm:
  5. Mollygoogle
    Mollygoogle Member
    227
    My money is on the HID ballast causing interference
  6. Ian2012
    Ian2012 Active Member
    473
    29
    could be earthing have you scanned the car for fault codes?? that would be my first port of call
  7. AudidriverA4
    AudidriverA4 Member
    182
    Hi Mollygoogle, sorry my car has the standard bulbs in it.
    That would be mine too Ian but, I have no VAGCOM just started the tread to see if it could be a simple fix, as I'm sure the car is not displaying the lights for no reason :think:
  8. quattrojames
    14,050
    573
    If it's none of the obvious we're all guessing really, ABS sensor would be my next guess.
  9. Ian2012
    473
    29
    You need to find a forum member with vcds to help out, or invest in the system yourself, if you are into audi's longterm then it will save you a fortune in diagnostic costs, mine has saved me a fortune over the years.
    It could be your abs ecu is on the way out, but really without plugging in diagnosing it's hard to say.
  10. Neilb1
    Neilb1 Member
    178
    intermittent brake light switch, it might be working when you check it, mine did the same
  11. Mollygoogle
    Mollygoogle Member
    227
    Sorry, misread your first response about no HID's
  12. AudidriverA4
    AudidriverA4 Member
    182
    Thanks again for all the replies I know its impossible to diagnose to problem without a scan, your replies will just give me an idea what could be wrong with the car,
    This could be it, the next time the happens again I'll check my breake lights, hopefully that's all thats wrong with it :laugh:
  13. AudidriverA4
    AudidriverA4 Member
    182
    No problem mate.
