A4 quattro maintenance manual?
whinfs Jun 12, 2013
  1. whinfs
    whinfs Member
    58
    evening
    is there a maintenance/service manual to cover the A4's quattro bits? im wondering what else needs servicing which isnt covered by the red haynes manual.
    cheers
  2. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    358
    The quattro propshaft and other associated hardware shouldn't give any issues. However, like anything it's subject to wear and tear. A visual inspection will confirm any play in the central bearing U joint or leaks from the driveshaft seals. The rear diff can use an oil change, or at the very least check the level. If changing - get car up to temperature and always pull the filler plug before the drain plug.
    I changed the gear oil on mine at 110k. Looked like Mellow Birds! :laugh:
    This is a useful site with pics too for B5/B6 (effectively the same)
    AudiWorld Tech Articles
    B6 A4: How to change your rear diff oil
