A4 Quattro driveshaft flange removal
Cam Feb 6, 2013
  1. Cam
    Cam Member
    33
    I have a 1999 A4 quattro. The outer CV boots were torn. Ive split the driveshaft and replaced the boot. I also want to renew the flange oil seal insde the gearbox but cant get the stubby part of the driveshaft out. Can anyone explain how to do this.
  2. aragorn
    18,315
    808
    its essentially pressed into the bearing inside the box, you'll need to use a pry bar or puller or similar to get it out.
  3. Cam
    Cam Member
    33
    Thanks for your message. Will it slide out if pulled with some force?
  4. aragorn
    18,315
    808
    yes, but you'll need a slide hammer or similar, pulling it with your hand isnt going to do anything.
    As for getting it back in... good luck :p
  5. Cam
    Cam Member
    33
    This is a job i havent done before. Any advice on how to get it back in?
  6. aragorn
    18,315
    808
    ETKA says "Drive in with drift VW295" :p
  7. Bradderz_1988
    3,951
    235
    Block off wood and a hammer !!!! Lol
