A4 owners - do this today and save yourself over £150!
quattrojames Nov 19, 2009
  1. quattrojames
    14,050
    574
    The glovebox hinge on A4's have a damper to allow the lid to drop gently. Over time these get stiff and they WILL break the hinge. For ages I've been thinking "Soon I must lubricate that damper" - but I left it too late and the hinge broke :banghead:
    This will take you one minute at most!
    Pop the end of the dashboard on the passenger side and you will see the damper. Lubricate the barrel with a silicon type lubricant and replace. Save yourself the griefy glove box fix!
    Credit to Marc1 for the following: It is possible to remove the damper and split it and take out the O ring which provides the damping. The glovebox will still work fine but the damper will not be stressing the weak hinge.
  2. markyzs180
    markyzs180 Member
    543
    Thanks James.....another little job for the weekend....
  3. BahnStormer77
    BahnStormer77 BahnStormer
    2,757
    54
    thanks.... and now I just need to remember to do this!!
  4. paul20v
    paul20v Audi fanatic
    1,113
    Mmmm i will do this soon
    bet i forget thou :)
  5. BILKO1
    BILKO1 Member
    301
    When mine broke i repaired it and lubed the damper but it was still very stiff so i drilled a hole in the end of the damper tube and it worked a treat.
  6. Marc1
    Marc1 Member
    728
    Good skills James. No need to credit me, I probably read it on here anyway. That's what the forums are for sharing the knowledge. :beerchug:
  7. dansansome
    dansansome Member VCDS Map User
    165
    already broken :(
    this damper unit also provides glove box locking with the central locking doesnt it?
  8. quattrojames
    14,050
    574
    I don't see how? Unless you know otherwise .... There is no link between the damper and the lock, and the only wire there is for the switch on the damper that activates the glovebox light.
    For everyone else - try and remember! I cannot over emphasis how easy it is!
  9. dansansome
    165
    after looking at your other repair thread, i realised mine isnt broken, what IS broken is teh little pin that connects the end of the damper to the glovebox hinge. phew, no need for immediate repair.
    the light switch makes perfect sense. i looked at it quickly and though that teh damper was actually a solenoid that just locked out with the central locking.
    judging by how easily the little hinge pin borke, it wouldnt have been all that secure lol.
    cheers for the reply :)
  10. quattrojames
    14,050
    574
    The damper part no. is: 8E2 880 324.
    The hinge pin part no. is: 8E0 880 802.
    Piedone likes this.
  11. dansansome
    165
    thanks again James :)
  12. JohnboyC
    JohnboyC Member
    858
    13
    Don't laugh - my glovebox hinge on the side nearest passenger door broke today........hinge looks like it has sheared off....
    Its £101 for a whole new Glove Box lid ......sheesh !
    (The worst thing is that I have had a new damper assembly sitting in my glovebox for months...never got around to fitting it)..
    That'll learn me :motz:
  13. BILKO1
    BILKO1 Member
    301
    Thanks James didn't know the damper was available separately.
  14. Funkyfin2000
    Funkyfin2000 Member
    489
    Perfect, got this sorted on mine today! job easy done and a b it of WD40 saw it right :D
  15. jd26
    jd26 Member
    276
    Ow Thanks for this thread mate will have a look at mine, its gone a bit creaky
  16. scott b
    scott b Active Member VCDS Map User
    1,254
    job for tomorrow whilst at the unit
    nice one cheers
  17. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    my glove box seems to just drop open when i flick the catch, can anyone film and upload what its meant to look like in action?
  18. quattrojames
    14,050
    574
    You'll probably find the damper has either broken or become detached. It shouldn't be hard to diagnose.
    I can't see my film of glovebox closure getting many youtube hits....!
  19. Funkyfin2000
    Funkyfin2000 Member
    489
    i wd40'd mine and its now rather quick opening........but i guess it will sort itself out :)
  20. Turkster
    2,797
    47
  21. crazypainter
    crazypainter Member
    590
    Done, a good heads-up there. Thank very much!
  22. Marc1
    Marc1 Member
    728
    James, One year on and your thread is still helping others. :icon_thumright:
  23. crazypainter
    crazypainter Member
    590
    Looks like the thread has lasted longer than the gloveboxes themselves. I couldnt believe how flimsy that mechnism looks!! like something from a christmas cracker........a very cheap christmas cracker. No wonder they give up so easy......and then charge a small fortune to repair. Deliberate under-engineering me thinks!
  24. LandSpeed
    LandSpeed Member
    229
    after reading this repair thread ive just been into the garage to lubricate the damper and.........there was no damper !!!
    anyone one remember how much it is for a new damper ?
  25. A4 nut
    A4 nut Member
    351
    Just lubed mine but the damper is still stiff hopefully it will work its way arround and loosen it up.
  26. Funkyfin2000
    Funkyfin2000 Member
    489
    Get the WD40 straw right up the damper if you can and pile it in. Mine was like that until i did that!!
  27. scott b
    1,254
    put some spray grease on mine made a massive difference, nice one
  28. Mike B
    Mike B Well-Known Member
    1,101
    40
    My damper is snapped .Audi say still same part and cost£16 plus vat .Seems they sell lots cos they had part no without checking
  29. Mike B
    1,101
    40
    Fitted new damper and it siezed .Had to cut off the pin cos they are not designed to come out and need force to push in.Audi reluctantly gave me another saying they could not sell the original again cos it was marked where I had cut through the pin ignoring my saying that it had seized and the lid had to be forced open.I soaked in the wd40 until the replacement was moving with almost no resistance and fitted with a split pin held there by a wire so that it could be removed easily. The lid now needs aslight pull to open slowly and becomes freer as the lid is moved so if it stays like this it will be acceptable and the light works but you would think that a redesign is a must
  30. quattrojames
    14,050
    574
    I'll bump this for newer members.
  31. Chrisavant
    Chrisavant Member
    42
    My damper got stiff and eventually broke the hinge before I read this thread! My solution was to drill both sides of the break and insert a small piece of stainless wire as a dowel, glued into both sides and on the break itself. I then reinforced top and bottom outside faces with glass strands embedded in more plastic glue. Sounds bodgy but actually quite smooth and neat. Only visible with door fully open and very close peering.
    I disconnected my damper completely to take the stress off the hinge. The action isn't so sexy but the hinge is happier and has been fine for over two years now.
    But now the opening release handle has become disconnected from the espangolette (?) bolt inside the locker lid. This meant that I couldn't get my wallet out of the glove box. Not many people have thought of that one!
    However by popping off the end of the dashboard, it is possible to push in the end of the bolt through a thoughtfully provided hole in the base of the lock keep recess, and this also automatically retracts the bolt at the inboard end of the locker door, so now I've got it open. But I cannot find how to get inside the door to fix it. The inside is a smooth black plastic moulding and the outside skin is textured matching the cabin trim, but there seems to be no means of separating the two mouldings. The only fixture I have found is a torx screw head adjacent to the inboard bolt.
    Anybody got any ideas, please?
  32. quattrojames
    14,050
    574
  33. Chrisavant
    Chrisavant Member
    42
    Thanks Quattrojames once again! You second link looks like what I need, but actually it's the same as the first one! If you do have the correct link I would be most grateful. I did see another photosequence on here, actually about hinge repair, but showing somebody actually separating the inner and outer shells of the glovebox lid by breaking a large number of thermal welds inside the door with a paint scraper. It looked pretty destructive, but did expose the sliding bolts mechanism.
  34. quattrojames
    14,050
    574
    Sorry, user error! I've not been able to access the site on Firefox all night so I've resorted to using my phone.
    It should be fixed now anyway.
    That post you mention refers to another way of mending the hinge, it depends how far you need to go! Mines held for a couple of years and I'm happy with it.
    You don't need to split the lid to get the catch out, just undo that screw and it will come out. The hardest bit is opening the lid which you've already done! £22 ish for a new catch from memory and easy to fit.
  35. Martin69
    Martin69 Member
    165
    Why am I only seeing this thread now :banghead: ... EPIC Thread :applaus: ... thanks a million lads... was thinking about spending money on a new glovebox :rock:
  36. quattrojames
    14,050
    574
    I'll bump this due to the recent glovebox damper discussions!
  37. MrG A4
    MrG A4 New Member
    27
    Thanks James, it's always good to know tips like this!
  38. StuG808
    StuG808 1.9tdi130 Avant FailWheelDrive
    255
    9
    Thanks for the info, I used it to perform a similar operation on my car. The only difference was that I used bolts and nuts as opposed to self tappers. Being that I had to part the two skins on the glove box to fix the spring that came off the closing latches, I reckoned that while it was apart that using bolts and nuts would give a more secure fixing. It all worked great, the hinges are now very strong and the spring catch works fine. But now it's all back together I wish I used a locking glue on the nuts so they won't wiggle loose over time..
    The glovebox seemed to have various previous attempts/bodges as the broken hinge was smeared with glue and the opening damper is missing. I'm still wondering if I should bother getting a damper or just leave it AWOL..
  39. unitzero
    unitzero Bagged B7 170 TDI Avant Audi A4 Black Edition
    568
    198
    43
    thanks for the bump, my lid had stopped damping and needs to be manually pulled all the way down. tried some thick grease on the damper but hadn't worked, so I'll squirt a good amount of WD into the mechanism and see if it helps matters. at the moment I can actually see it stressing the part where it's attached at the side of the box. it's deffo seen better days.
  40. CHEZ
    CHEZ moderately amusing Supporter
    4,171
    839
    ok so carried out this precautionary measure out today and now have a couple of issues,
    firstly, my glovebox lid was ok,it opened and closed ok, with a sort of dampened effect on opening, but with a slight stiffness on closing, i followed james"s advice to "er" on the side of caution and service the damper to save on a costly repair in the future.
    i used GT85 as i feel its a bit posher than wd40 (and is all i had anyway),
    i removed the side plate of the dash, located the damper, placed a cloth underneath, and blasted GT85 into the damper using the straw.
    i then worked the glove box lid up and down a few times to get the oil into the damper.
    now, it seems the GT85 has disolved any grease in the cylinder as the glove box lid just drops really fast when opened!
    the damper is working because i can hear it making a squelching sort of dampening, hissing noise! (if that makes sense at all!)
    its just now that it drops so quickly, surely that wont be doing the hinges any good, as its not really taking the shock out of it!
    so my question really is, can i use any type of grease to put on this plastic damper? can you purchase plastic grease? or would something like vaseline work as a thicker lube rather than a very thin lube like i have used?
    thanks in advance
    chez!
