A4 not revving past 3000
swalder Dec 28, 2013
  1. swalder
    swalder Member
    93
    Guys out shopping :( so kind of hard to search every post but had a look and looking some advice.
    Merging onto the motorway behind a slow moving horse trailer. So accelerateon past then all of a sudden power dropped out and it was a struggle to hold 60mph.
    No power in any gear and I can't hear the turbo . Once I got off the motorway found the car won't rev past 3000rpm.
    I am now way technical but from reading maybe the maf has gone or the hose for the tyrbo.
    Anyone any suggestions on what can be done or what I should look at?
    Its a 2.0 tdi
    Cheers guys
  2. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    Any warning lights on your dashboard? Sounds like your car has gone into limp mode.
    BR
    A
  3. Broken Byzan
    13,237
    465
    boost pipe off? Is it smoking a lot of black smoke when it is working?
    You could try disconnecting maf to get you home and drive carefully
  4. swalder
    swalder Member
    93
    I am not technical in any way . Can you point to me where the boost pipe is ? I could have a look ?
    Although if it were off completely surely the turbo wouldn't spool at all. Just the second drive there albeit short to the next shopping centre :( the turbo was engaging and it operating normally again.
  5. swalder
    swalder Member
    93
    just a bit more of an update drove home around 15 miles . Everything was fine , drove normally didnt horse it or demand too much pressure onto the turbo.
    Cant understand why it would have entered limp mode as the dash had zero warning lights etc.
  6. Broken Byzan
    13,237
    465
    ok, i'd be getting it scanned for faults. I cannot imagine an intermittent fault will remain so for long
  7. hubbo1
    hubbo1 Member
    117
    if it went into limp mode because of sticking turbo vanes, its unlikely to throw up a warning light.
    before I cleaned my turbo mine used to do this-foot down and bang=into limp mode, turn engine off and back on again=all normal.
  8. swalder
    swalder Member
    93
    How hard is it to clean the turbo or how expensive to get a mechanic to do it ?
    Cheers for the help .
  9. hubbo1
    hubbo1 Member
    117
    just search on here for "mr muscle" turbo clean, its not a hard job, just search- sticky for turbo cleaning, its all in that thread
  10. swalder
    swalder Member
    93
    cheers buddy !
