A4 new engine..not running properly
Thatch85 Mar 25, 2012
  1. Thatch85
    Thatch85 Member
    33
    Just put a replacement engine in my a4 tdi. Car is now struggling to start. Once it's started it ticks over fine. But when driven its lost all power, seems to be miss firing and plenty of smoke from the rear? Smells strongly of fuel. Any ideas what's going on?
  2. adamss24
    adamss24 Well-Known Member
    4,584
    406
    What year and engine code ?
  3. Thatch85
    Thatch85 Member
    33
    2006. Engine code brb
  4. chrisk1700
    chrisk1700 Member
    92
    hi mate, you have exactly my issue. was it a second hand engine? and did you swap ecu's too?
  5. Kalashnikov
    Kalashnikov Active Member
    231
    44
    Brb = be right back /or maybe not
  6. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,620
    2,538
    I am assuming you have installed a complete replacement engine, was it exactly the same engine code as the original.
    Different engines use different injectors and if the injectors don't match with the ECU you can get these kinds of issues.
    You also have an unknown in the engine that you have installed. Things like cam timing will affect the engine running and how much power it makes.
    If it is a different engine code to the one you have now what is your existing engine code and the engine code for the new engine.
    There is quite often a sticker on the cambelt cover with the engine code.
    karl.
