A4 MODS VIA VCDS?
vw754 Oct 29, 2013
  1. vw754
    vw754 vorsprung Durch Technik
    2,347
    58
    hi,ive done needle sweep via vcds on my b8,any others available? can i change the screen display so it displays the 's-line' logo (no,i dont have sat-nav)
    Is there a way i can enable a bleep when i lock the car?
  2. hollows wife
    hollows wife Well-Known Member
    1,404
    164
  3. vw754
    2,347
    58
  4. vw754
    2,347
    58
    nice one for that,still cant find what im looking for,maybe someones done what i want,hopefully
    <br>
    <br>
  5. hades-
    9,482
    646
    you cant change the screen to s-line
    you can have a beep with alarm
  6. hades-
    9,482
    646
    horn with alarm arm disarm
    once coded you can alter it in the MMI menu
    The following coding is used:
    • Acknowledgment of the close
    1. Select STG 46 (comfort)
    2. Long STG coding -> function 07
    3. Byte 1
    4. Enable bit 2
    • Acknowledgment for the open
    2. STG adjustment -> function 10
    3. Channel number 63
    4. Default: 40
    5. Change to 44
  7. hollows wife
    1,404
    164
    not sure wether it was explained in that thread what you required,it was more a general list of what can be done with vcds
    vw754 likes this.
  8. vw754
    2,347
    58
    THANKS,IL TRY IT NOW
  9. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
    xpoweruk likes this.
  10. vw754
    2,347
    58
    NICE 1 ! works now
  11. Point_Audi
    Point_Audi Vorsprung durch Technik Staff Member Moderator VCDS Map User Gold Supporter Team Tornado Audi A5 Black Edition S-line owners group
    1,393
    977
    Done a few mods myself, some of which are listed on the links provided above:
    - Enabling Needle Sweep
    - Passenger Mirror Tilt When Engaging Reverse
    - Adjusting Length Of Time Before Automatic Main Dip Comes On
    - Beep Alarm When Locking The Car
    - Lap Timer
    - Emergency Brake Flashing via Indicators
    - Display Graphic Interface When Engaging Reverse For Parking Sensor
    - Battery Meter Level Displayed In MMI Menu
  12. Christian_a4
    Christian_a4 Member
    61
    17
    Ive just enabled:
    needle sweep
    mirror tilt when reverse selected
    didnt fancy lap timer
    hazards flash under harsh braking
    i also turned up the brightness value of my DRL's and they are fooking bright now!!!
  13. Point_Audi
    1,393
    977
    Don't quote me on this, but I think the brightness of the LED's is only when you have your dip on, when just DRL the brightness stays the same as set by Audi.
    The lap timer also shows the temp of the oil etc, which is just nice to see. If its possible why not switch it on! :)
  14. Christian_a4
    Christian_a4 Member
    61
    17
    Well they seem a lot brighter any other time. I.e: coming home function ect..
    i did turn on the lap timer but it turned the words a different colour which i didnt like haha!
  15. SI-W85
    SI-W85 Well-Known Member
    1,321
    351
    Is the mirror dip only on cars with comfort pack ie electric seats and folding mirrors or can it be done on any model as I have the sline executive model but it doesn't have the electric seats?
  16. hades-
    9,482
    646
    works on all models
  17. SI-W85
    1,321
    351
    Ok that's great as that is the main one I wanted but was told I needed comfort pack ill give it a go thanks
  18. Gillm
    Gillm Member
    110
    Hi guys just got my lead from NHN ( super fast delivery by the way) I'm struggling with the hidden menu ? Im trying via 5f but it's not finding anything ?
    Im im ideally trying to ad battery meter and alarm honk !
    Any ideas ?
  19. Rodders.
    Rodders. Active Member
    183
    This thread makes me want a cable now!!
  20. hades-
    9,482
    646
    alarm codeing is above
    3. Byte 1
    4. Enable bit 2
    4. Default: 40
    5. Change to 44
  21. hades-
    9,482
    646
    On the radio control unit, you have the option of the Audi A4 8K to activate the battery indicator for the radio Concert / Symphony.
    1. Select STG 56 (Radio)
    3. Channel 39
    4. Increase value by +16
  22. johnnevett
    johnnevett Member
    245
    19
    How do I adjust this
    thanks
  23. SI-W85
    1,321
    351
    Anybody in the Huddersfield area or surrounding have a vag com who can do me a few mods to my car will pay for your time???
  24. hades-
    9,482
    646
    Sheffield
  25. SI-W85
    1,321
    351
    Is that you in Sheffield bez101 ?
  26. hades-
    9,482
    646
    yes so if your ever over here feel free to email me
    im on days all next week till about 6pm
  27. SI-W85
    1,321
    351
    Very good of you, I'll be sure to do that thanks
  28. johnnevett
    johnnevett Member
    245
    19
    Can anyone help with the coding to adjust the amount of time before dipped light come on
  29. SI-W85
    1,321
    351
    Do you mean for the auto headlights? Because I think mine come on way too early if so would also like this doing :)
  30. johnnevett
    johnnevett Member
    245
    19
    yeah for auto headlights.
    Point_audi says above that he has adjusted his. So there must be a way.
  31. Rodders.
    183
    Where did you find the graphic interface when reversing? Thought I saw it once, but cannot find it for the life of me
  32. hollows wife
    1,404
    164
    i know that once activated you can adjust it in the mmi ,car setting ,exterior light option. have a look might be there already
  33. johnnevett
    johnnevett Member
    245
    19
    yeah, adjusted in MMI but still come on very early. Thought there might be an adaption code change.
  34. hades-
    9,482
    646
    only the mmi setings for early late etc
  35. johnnevett
    johnnevett Member
    245
    19
    so you can't adjust when early/ late is with VCDS.
  36. hades-
    9,482
    646
    i get you
    in the B7 you can so i should think you can in the B8
  37. johnnevett
    johnnevett Member
    245
    19
    i would think you can, it's just which no's to adjustr
  38. Rodders.
    183
    Managed to get everything working I wanted, except mirror tilt when reversing. I don't have module 76, could this be why? I thought it was suppose to work on all?
    Bit 4 and 2 set to 1
  39. Point_Audi
    1,393
    977
    Just set bit 2 for the mirror tilt! :)
  40. Rodders.
    183
    Ok. Will go and try again
