A4 Lighting Pack Retrofit?
kaskat Nov 20, 2005
  1. kaskat
    kaskat New Member
    Anyone here fitted footwell, puddle and mood lighting as comes with the lighting pack to their A4, just wondered if it was possible /ubbthreads/images/graemlins/cool.gif
  2. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    just trying to find the right wiring,im on the job!
  3. jonmusicman
    jonmusicman Member
    176
    Oo-er!! lol
  4. Sinny71
    Sinny71 S55 LKS
    779
    The mood lighting is a doddle. The roof panel is marked up on the back as to where to drill the two holes. I was told to use a 7mm drill bit but in truth I used a 3mm and gradually worked up using bigger bits to 6mm. Think I'll leave it there.
    The lights themselves clip into place and you just need to undo 2 screws to connect the wires.
    This was all done on a B6 but I'm sure(ish) that the B7 is the same.
    Not even thought about the puddle lights though.
  5. jase0851
    jase0851 Member
    789
    did you manage the job then ?
  6. vw754
    2,345
    58
    Looking good now,job done!
  7. jwhat
    jwhat Member VCDS Map User
    541
    So did you manage to get the mood, footwell and puddle lighting working? Was it expensive? Hard to do?
  8. stevehall
    stevehall Member VCDS Map User
    300
    I want to add footwell lights to my B7... Did this get done?
    Any guides?
  9. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
    Anyone actually go through with this?
  10. stevehall
    300
    I have not done it yet, but still on my to do list.. plus would like someone to do it first.
  11. quattrojames
    14,050
    578
    I've just started a similar thread in the B6 section, there's some links and part numbers in there, and I'll be doing it sometime soon.
  12. wyliss
    wyliss Member
    286
    B7 is the same, just to confirm. Part only cost £8 and it gives a nice effect to gear lever area.
