A4 immobiliser problem
Deanh Oct 21, 2012
  1. Deanh
    Deanh New Member
    Been having problems with my immobiliser,
    battery died a few months ago and as it was dying the immobiliser would kick in after 2 seconds of starting which I put down to the weak battery,
    put a new battery on but had the same problem since, meaning to start the car I have to disconnect the battery for 20 seconds and as soon as I switch it off I have to do the same thing again to restart it,
    Its been to the garage twice and put on vag com and 50/504a and on vag com it says the key signal is too weak, the instrument panel is clear of faults, and on the 50/50 software says the ecu is in static mode and won't talk to the immobiliser!!!!
    anyone any ideas?
    i have tried a more powerful battery but that still has the problem so I know it's not a battery fault and my key has no battery in it
  2. aragorn
    18,293
    802
    I think the battery is a red herring.
    The normal immo activation is to shut the engine down after a second or two, so what you describe there isnt anything battery related.
    Have you tried another key?
    Might need a new reader coil, or sometimes the wiring to the coil causes issues.
  3. hades-
    9,481
    646
    as above iv sorted quite a few B5's with immob problems
    changed the wire from reader and all was good
    easy ish job to do and parts not a lot of £££.
  4. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    where is the reader and how do you remove/replace/repair the wiring?
  5. aragorn
    18,293
    802
    Its part of the ignition barrel.
    Not sure if you can swap the reader on its own, or if you need to buy a whole new barrel though.
    The wiring on earlier cars can prove problematic though!
