A4 Headlights
AndyMac Jun 11, 2003
  1. AndyMac
    9,832
    45
    Anyone know if there is a Xenon (clear lens) replacement headlight available for 1997 A4?
    Hella don't seem to do one.
  2. excursion
    excursion Member
    740
    order the ones from the 1998 S4, or alternatively you can fit the later headlights with a bit of modification. It's very easy to do.
  3. PunjabiA4
    PunjabiA4 New Member
    12
    Hi m8! yes as suggested you could either get the 1998 S4 xenons which are a tw0 piece version or fit in the one piece set but with modification. The modification involves cutting a little bit of metal! /ubbthreads/images/graemlins/idea.gif. there is a metal lip about 1.5cm where the front indicator lens sits...you need to remove this so that you can fit in the one-piece. The wiring (if you can get hold of the original wire loom is the same! colour so that pee easy...but i couldn't connect the level adjustment as it was controlled by the rear suspension on the S4) I did this modification a couple of years back. Got the lights second hand off allaudi..for about 330 then.
    I believe In Pro do a two piece projector headlamp but i don't think that is xenon.
    here's mine:
  4. AndyMac
    9,832
    45
    Thanks for the advice. Like the RS grille by the way. Looking Good!
