A4 Cabriolet soft roof problem..
sn00pydk Apr 28, 2012
  1. sn00pydk
    sn00pydk New Member
    Hi. i have upload a video with the fail on youtube Audi A4 Cabriolet soft roof problem / A4 Cabrio verdeck problem - YouTube
    and i have manual take the roof up and down for reset switches..... but no luck :-(
    when i turn the ignition on the roof warning light will flash 10 times and then stop
    i have vcds to read and clear error.
    Torsdag,26,April,2012,18:48:04:42057
    VCDS version: NEZ 908.1
    adresse 26: El.tagbetjening Forklaringsfil: 8H0-959-255.lbl
    Styreenhed reservedelsnr. : 8H0 959 255
    Komponent og/eller version : VSG B6 CABRIO 6184
    Software kodning :
    Forhandlernummer : WSC 00672 785 786632
    2 fejlkoder fundet
    02000 - Kontaktposition
    008 - Urealistisk signal
    01986 - Føler til spændbøjleposition - kaleche (G356)
    Regards Carsten
  2. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    Don't know anything about codes, but since you've had no other responses... It looks like the motor is struggling to open the hood cover, then once it's reached the open position is just falls back down again. Have you followed the repair guide for the motor in the boot? Maybe check to see if the support struts are leaking and hence not providing enough force to hold the cover open?
    Not 100% sure if this will fix your problem but it might be worth investigating: http://www.audi-sport.net/vb/audi-s...et-soft-top-roof-hood-motor-repair-guide.html
