A4 Cab b6 alarm horn short to ground.
Cabbyfan May 24, 2013
  1. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Hi,
    had the dreaded alarm siren failure by corroded batteries etc. Fitted a new second hand unit today and still hazards flash but no sound. Scanned with vcds lite and get...
    01134 alarm horn h12 29.00 short to ground.
    soon as I clear it then it returns.
    Im not actually sure it's a fault of if the rechargeable cells inside have to charge up first before I will hear any sound. Does anyone know ?
    Many thanks.
  2. NHN
    29,510
    1,764
    Mine worked straight of the bat, so you sure its not a faulty unit again, definitely new unit as second hand & new in same sentence seems contradictive :p
  3. Cabbyfan
    840
    34
    Thanks for the quick reply. It was an ebay job, stated as tested and working but hard to tell. It was listed as for a TT but pared code is identical to the one I removed. I'm wondering if it does need charging up from the car first though.
  4. NHN
    29,510
    1,764
    Well take it for a little run, that will give it a charge, check your coding is correct aswell for horn warnings, then test.
  5. Cabbyfan
    840
    34
    Roger that. Cheers. Will update later.
  6. Cabbyfan
    840
    34
    Well it's been on a 40 mile drive, still no sound only flashing lights. When I scan with vcds lite I get the h22 short to ground, if I unplug the siren I get the no communication error as you would expect. I'm wondering if my ebay purchase is a duffer.
