A4 Brake Warning Light
fleecyphil Mar 14, 2012
  1. fleecyphil
    fleecyphil New Member
    Hi Guys
    Can anbody help with wiring diagram & relay details to cure this problem.
    Light comes on after cranking engine,scanned for faults & non showing,have contacted Dealer they say needs relay fitting to cicuit.
    Any help would be much appeciated.
    Regards Phil
  2. NHN
    29,351
    1,720
    Scanned for faults with what?
  3. fleecyphil
    Scanned with VCDS & SNAPPY
  4. hades-
    9,481
    646
    battery on its way out can cause this
  5. alpesh26
    alpesh26 Active Member TeamMisano
    417
    43
    As above.
    Mine did the same, no faults being thrown (checked with VAS). Changed the battery and its been fine since.
  6. fleecyphil
    Will test battery just to be sure,but seems to crank over well.
  7. murran
    murran Well-Known Member
    1,545
    39
  8. NHN
    29,351
    1,720
    Does the reservoir have the 2 prongs inside like the coolant version?
    If so, scratch the surface of the 2 prongs, these fixes the coolant level sender.
  9. murran
    1,545
    39
    i dont think they do. you can pull the sensor out. but its just a black oblong bit of plastic that slides in from the side, theres a two pin plug to the cars loom.
    theres a little float and some mechanism inside the reservoir, never bothered chopping a reservoir up to find out how it works tho.
    all i know is ive fitted reservoirs, 8 or 9 in the past 2/3 years.........
    im guessing theres a bit of dirt/water in the sensor mech/float thats succeptable to cold for some reason that combinded with the drop in voltage on start up causes it to flash up.
    its not just diesels either, fitted one on a fwd red 1.8t, thats the most recent one a couple of weeks ago.
  10. NHN
    29,351
    1,720
    Ah you see everydays a school day :)
  11. janzbro
    janzbro New Member
    17
    mine had this fault when we bought it - the garage replaced it with one from another A4 they had in but it was still happeing so they had to take it into Audi and have a brand new unit fitted - touch wood its been fault free since.
  12. fleecyphil
    Thanks for all the replies,will try this during the week and hope cures problem.
