A4 B8 Rear Bumper removal guide/help?
sduk Jan 21, 2011
  1. sduk
    sduk Audi Baby!
    149
    19
    Hi folks, gonna be removing my rear bumper to fit the s-line diffuser soon.
    Is it an easy job to remove the back bumper?
    Can anyone offer any advice or a guide on how to do it? How many screws etc?
    really would appreciate some help,
    thanks
    Sammy
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    Saloon or Avant?
    Edit:=- I can email you the instructions from Elsawin if you would like.
  3. sduk
    sduk Audi Baby!
    149
    19
    Sorry should have said it's a 2008 a4 b8 saloon. If you could send the instructions to sduk @ hotmail . com that would be great.
  4. ScottD3
    15,164
    1,123
    On their way.
  5. sduk
    sduk Audi Baby!
    149
    19
    Thanks very much. Had a check there and don't seem to have the email yet.
    Does anyone know if it's an easy job? I'm hoping the diffuser is easy enough to clip out
  6. ScottD3
    15,164
    1,123
    Check your junk folder.
    Its been sent.
  7. sduk
    sduk Audi Baby!
    149
    19
    hi got the email, thanks very much, what programme do you use to open the file? I am on windows XP and tried to download a .xps viewer however cannot find one that works. any ideas?
    thanks again for your help. really appreciate it :)
  8. ScottD3
    15,164
    1,123
  9. guli
    guli New Member
    Hi ya Axios,
    Can you kindly email me the same file too please? My email is puccibuy at g m a i l dot c o m
    Thanks!
  10. ScottD3
    15,164
    1,123
    Done.
  11. sduk
    sduk Audi Baby!
    149
    19
    thanks for the email, got it! managed to download a mozilla firefox addon to view it aswell!
    its pretty complicated viewing tho!
    can anyone who has removed the rear bumper offer any advice or help for me?
  12. Zafi
    Zafi Well-Known Member
    1,299
    326
    From my Witter towbar instructions......
    Remove Bumper
    Remove boot floor mat and side storage boxes, remove the plastic nut inside each wheel arch
    beneath light clusters, remove the rear plastic panel and the plastic grommets to reveal 1 nut each side, remove nut
    taking care not to drop it inside, remove the 2 torx head fixings securing the luggage strap retainers.
    Remove the fixings along the lower edge of bumper and the screws around each wheel arch.
    As you pull it off you need to flex the wheelarch part outwards a little.
    Its a 2 man job, before you start, set out a cloth to put it on.... or put it on the lawn.
    aphill24 likes this.
  13. sduk
    sduk Audi Baby!
    149
    19
    thanks for the guide mate, have you done it yourself? how did you find it?
    im not looking forward to doing it but need to, to fit my s-line diffuser :)
  14. M90KKL
    M90KKL Active Member
    221
    35
    Did u ever get this done?
  15. Zafi
    1,299
    326
    I have done it three times without problems.
    Last time I did it all by myself.
  16. Chop.
    Chop. Well-Known Member TFSI Owners Group Team V6 Silver Supporter Audi S4 quattro Audi Avant Owner Group s tronic Supercharged
    1,731
    1,760
    guys if your just after a diffuser change i have a guide on here from my 2009 s4 b8 diffuser comes off without removing the bumper
  17. Harry Horlock
    Harry Horlock HH-UK
    Hi Chop, do you still have the guide to removing the rear diffuser without removing the Bumper??
  18. Chop.
    1,731
    1,760
    Yeh mate it'll be here somewhere I'll try find it
  19. Harry Horlock
    Harry Horlock HH-UK
    Thanks for your help buddy, I tried it and felt like it was going to break so I ended up taking off the rear bumper But it's all fitted now so all is good... thanks again for your help much appreciated
  20. Chop.
    1,731
    1,760
    Good job mate, no problem at all
  21. enes
    enes New Member
    Could you email me those instructions as well ? I have an AUDI A4 2009. Not sure if it is compatable with that as well.
  22. Zafi
    1,299
    326
    Remove boot floor.
    Remove boot sides, disconnect 12v socket from right side.
    Remove mud flaps if fitted.
    Unscrew large plastic extended screw and remove light cluster each side.
    Remove the grommets in panel in boot below light cluster to reveal 1 nut each side, remove nut taking care not to drop it inside.
    Remove 3 fixings around wheel arch, 3 torx and one trim pin fixings on lower edge and one plastic pin hidden behind each light cluster.
    Unplug reversing sensor wire in right side compartment, it passes through a hole to bumper.
    Pull bumper sides outwards from wheelarch and remove bumper, feed sensor wire out of hole.
