A4 B8 coolant leak ?
Discussion in 'Audi S4/A4/A4 Cab (B8 Chassis)' started by luis.filipe, Dec 16, 2009.
  1. luis.filipe
    luis.filipe Member
    Jul 30, 2007
    85
    Hi,
    yesterday when I arrived at the car I remembered to check the coolant level, the car is a 2.0 TDI 170cv with 10 000 miles.
    I noticed that the coolant level is at the minimum (checked while the car is cold).
    Is this normal ?
    Does anyone have noticed something like this ?
    Thanks for any help.
  2. Advert Guest Advertisement
  3. luis.filipe
    luis.filipe Member
    Jul 30, 2007
    85
    The current coolant level is this . . .
    Tomorrow I'll go to the dealer and let's see what they have to say.
  4. johnnythepie
    johnnythepie Well-Known Member
    Apr 27, 2009
    2,242
    75
    Whats the level when its hot?Dont forget that liquids expand when the are hot
  5. luis.filipe
    luis.filipe Member
    Jul 30, 2007
    85
    Hi.
    When hot I don't get the same reading all the times.
    Sometimes I get the coolant level at maximum, other times I get it above the maximum.
    But, when the car was deliverd the coolant level when the engine was cold was at the maximum, and since then the level as been dropping to the level shown in the photo.
  6. luis.filipe
    luis.filipe Member
    Jul 30, 2007
    85
    Weel, went to the dealer, they toped it.
    Asked me to do a few more miles, and check the coolant level, lets see what happens :)
  7. Kuajo
    Kuajo New Member
    Dec 12, 2009
    I have the 2.0 T 210 CV...
    And he LOVES coolant! I have to refill it a couple of times each month... Same thing happens to my friend and he has a 2.0 T Golf GTi... Turbo engines love coolant..
  8. auroan
    auroan Active Member
    Jan 28, 2004
    1,672
    Thats just wrong. Doesn't matter if the engine is NA or Turbo. The Coolent system is a closed circuit until you take the coolent header tank cap off. So there is defo a leak somewhere.
  9. scoTTy
    scoTTy Active Member
    Jan 2, 2003
    1,962
    My B6 S4 had a coolant loss during warranty but the dealer couldn't find it. It was only very minor. i.e. maybe 1/2L every 17k miles.
    When it was out of service they found the problem - a mismanufactured block meaning it needed a new engine !!! Audi would only offer 40% (dealer offered another 10%) despite it being demonstrated to be a pre-existing condition.
    I got out of it and changed to my B8 A4 but if you're losing fluid get them to find it and to keep the car until they do!
    Be warned !!!
  10. Wilkinson
    Wilkinson Geordie
    Dec 8, 2006
    35
    Mine seems to be losing coolant also. In for checks on the 15th. Will let you know if anything found.
  11. Isoniazid
    Isoniazid New Member
    Jan 10, 2010
    I have similar probs. What did they say finally
  12. Wilkinson
    Wilkinson Geordie
    Dec 8, 2006
    35
    Visual check and pressure test found no leaks. Coolant topped up - told to continue monitoring the situation
  13. luis.filipe
    luis.filipe Member
    Jul 30, 2007
    85
    After 1900 miles, the coolant level when the car is cold, dropped from the max to the middle.
    I'll wait another 2000 miles to see it it reaches the minimum, if it reaches the minimum the dealer will have to do more than just top it up.
  14. Wilkinson
    Wilkinson Geordie
    Dec 8, 2006
    35
    Monitored since February. Now no drop in coolant level. Makes me think that there might have been an air lock since the car was new in July 2009 and that the garage possibly cleared it inadvertently by pressure testing. I used to get a very slight "gurgle" from the heater on start up but this has also disappeared.
