A review recently posted in Autotrader based on my experience.
Any other UK owners had similar experiences with this version of the B8?
"Good Points - Looks good, good fuel consumption
Bad Points
1. Oil consumption - piston rings burn out around 60 to 80,000 miles leaving you with very large repair bill. (Expect very little support from Audi UK)
2. Gear selection (FWD) - very hard to select 1st or 2nd gear in weather where temperatures are less than 10 degrees centigrade.
3. Gear ratio's - 2nd gear ratio is unsuitable for town driving. If you slow to turn into a street, you will stall the car trying to do it in 2nd. You will have little choice but to select 1st (if you can get it into 1st, see previous point) - well lets say Audi makes it a challenging manouevre.
4. Torque steer - FWD model is Incapable of transmitting power to road. Wheels very quick to spin (even with new michelins) and car has strong desire to pull from left to right
5. Tram lining - Car has strong tendency to follow camber of road or ruts left by lorries. 4 wheel Tracking and tyre changes does not resolve.
6. Suspension - So soft it is like riding a boat. Make sure you get S-line spec.
7. Paintwork - exceedingly thin, easy to scratch and very susceptible to damage from 'suncream'
8. Unusual metallic grinding noises when pulling away from cold - apparently air box noise.
Many of these characteristics are well documented in forums, and according to dealers, the characteristics of the car.
If these are characteristics you like in your car - have fun."
Bad Points
