A4 B7 with a rattle related to the air con
Discussion in 'Audi S4/A4/A4 Cab (B7 Chassis)' started by ming, Jul 23, 2010.
  1. ming
    ming New Member
    Jul 11, 2010
    Tried a search on this issue but no joy.
    Just got a 55 reg A4 B7 2.0 TDI S-line saloon and need a bit of info.
    When the air con is switched OFF there is a random/irregular mechanical rattle from the engine bay. However, when the air con/climate control is ON there is no rattle.
    Any suggestions as to the cause?
  2. Advert Guest Advertisement
  3. jwhat
    jwhat Member
    Oct 20, 2006
    540
    If you do a search I'm pretty sure this has been covered before.
  4. TORQUE HEAD
    TORQUE HEAD Member
    Jul 17, 2007
    40
    RANDOM MECHANICAL RATTLE,
    I HAVE 54 REG A4 B7 2.0TDI S-LINE,65000ML
    I HAVE THE EXACT SAME PROBLEM AS DEISCRIBED BY MING ABOVE,RATTLE GOES WHEN THE AIRCON/CLIMATE CONTROL IS SWITCHED ON, AIRCON WORK'S FINE, COULD IT BE THE MAGNETIC CLUTCH IN THE AIRCON OR A TENSIONER ON THE PULLY RIB BELT,
  5. williams
    williams Member
    Aug 4, 2010
    78
    Got same problem, Is there a way to change drive belt to another so not using pump until I can get new one, as audi want £900 fitted OUCH!!!!!!!!
