A4 B7 Cab Audio Upgrade...
Joe_Murphy21187 Mar 11, 2012
  1. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,060
    71
    I'm planning to upgrade the speakers in my 2007 A4 cab, I haven't got BOSE and I'm wanting to keep the stock HU as I prefer the OEM look in the dash.
    Want to upgrade front door speakers and the rear panel speakers, plus hopefully a sub in the ski pass space between the rear seats. I'm trying to avoid using additional amps for the speakers, as a result I am looking at some alpine speakers which are relatively low power (25watt RMS) also shallow mount so should fit in the standard spaces and also be ok running off the factory HU. I'm not sure how to remove the front door cards but I'm pretty sure I'll be able to find a guide somewhere online, but if anyone has a link (have searched already but no joy so far), that'd be a great help! Once I've got them off I can confirm what size the speakers are (8" or 6.5"), as I haven't been able to find a conclusive answer about the cab speakers despite lots of searching.
    Found out how to removed the rear panels so when I've got them off I can do the same with the rear speaker sizes and looks for a decent upgrade.
    Next thing is the sub... having the sub itself exposed and facing into the cabin would be ideal (aesthetics and sound wise), so I'm looking at the Vibe Blackdeath square 6x9 'marine' sub. Already got a 700watt alpine d class amp so power isn't a problem. If I can remove the blackest I'm hoping to have it mounted on baffle board and use it as a free air sub. Spoken to the guys at vibe and as its basically the bass driver from their high power 6x9s that should work fine. Also means I will lose no space in the boot (small enough as it is) and will mount the amp behind/under the sub again in the ski pass space.
    [HR][/HR]Things I'm not sure on are:
    1. If the rear speaker high level inputs will be sufficient for the amp (either straight in or VIA a high level converter)
    2. Where to tap a remote turn on feed from to activate the amp, any help on this would be greatly appreciated.
    3. How bad in reality are the stock speakers? I've heard far worse car stereos in my time and it sounds acceptable if its not too loud. Am I going to notice much of a difference if I'm JUST upgrading the speakers and not amping them?
    4. Seemingly there are (in addition to the dash centre speaker) what I can only assume to be mid-range drivers in either side of the dash. Does anyone know how to remove/replace them and what size they are?
    5. The impedance of the facotry speakers (again, NON-Bose). I think they are 4ohms but can anyone confirm that?
    [HR][/HR]
    When I get the required info and some free time I'll keep you posted on any progress.
    Any input/thoughts/advice/suggestions/help is greatly appreciated!
  2. Joe_Murphy21187
    1,060
    71
    Bump, especially for the front door cards...
    Removed the rear door cards today and am now looking at the Infinity Kappa 50.9i components. 2ohms (factory are 3ohms), 2nd best low freq response I can find for the money and pretty low RMS power requirements... thinking of mounting the tweeters on the rear panels somewhere.
    Had great results with infinity speakers in the past and will almost definitely be able to get the same range to match in the front.
  3. AndyMac
    9,832
    45
    Don't think anyone has had any experience of a B7 cabrio. This is the guide to removing the door cards on a B6/B7 saloon and the current A3 is pretty much the same so it can't be that radically different.
    http://freepdfhosting.com/5a5f2d6ac7.pdf
  4. Joe_Murphy21187
    1,060
    71
    Thanks AndyMac.
    I found a guide (some kind of technical self teaching Audi guide) for the HU which I have but in an 07 TT, which said it used an external amp of 20watts x 2. Having been able to find NO info about it I'm guessing the a4 would be a 4 x 20watt amp somewhere.
    The Headunit is an rns 5.0. If anyone knows the HU/amp specs and also where the amp is (if there is one)...
    Also, no opinions etc on the proposed upgrade??
  5. AndyMac
    9,832
    45
    All Audi non Bose systems are 2 x 20w to the front speakers (powered by the HU) and 2 x 20w to the rears from a separate amp, then various configurations of 1 x 50w subwoofer, either in the parcel shelf or in a separate tupperware box.
  6. Joe_Murphy21187
    1,060
    71
    Thanks again Andy. Audi near enough confirmed it when I popped in today (based on their apparent lack of knowledge about their systems?)
    Can't seem to find any answer relating to upgrading to the Infinity speakers alone - some say you will lose mid-bass and speakers will be underpowered, others say they have had a great improvement over stock even without an aditional amp. Also cannot decide (if to replace the speakers) if it would be worth the effort to mount the separate tweeters in a component set in the rear rather than coaxials (coax have lower power req which is good if keeping stock HU etc).
    As there is no pre-out from the HU, if I were to replace the 2-ch amp in the boot (assuming wiring is in place to just swap it with a new one) with a 4-ch amp to power all the speakers rather than 50/50 from the HU, how would I get the power from the new amp to the front speakers and by-pass the output from the HU??
  7. AndyMac
    9,832
    45
    They will be better than stock only because the stock speakers are garbage, much better amped
    The HU does have pre-outs for front & rear, just on a Quadlock connector rather than standard RCA's, however in the non Bose system they only run the rear pre-outs to the boot, so not great if you want to amp all speakers. You will need to run RCA's from the HU to the boot then you can pick up the feeds to the rears from the connector on the amp, but you will need to run new speaker cable back to the HU to pick up the feed for the fronts
  8. Joe_Murphy21187
    1,060
    71
    So either way, if I'm going to amp all 4 speakers, I need to run wires to the front or to the rear and either tap into or replace the original wiring... this is turning out to be more work that I'd hoped. Unless I ran 2 2-channel amps...
    I shall plan for the summer and get a 4 channel amp to replace the one in the boot, run the appropriate wiring from the stock HU and take a feed from the Quadlock connector. Replace the amp in the boot and run wires to the front speakers from there.
    Thanks for your help Andy, if I ever get round to doing this I will start a thread lol
  9. puterg0d
    puterg0d New Member
    So, do you know what sizes all the speakers are?
  10. Gazthesparky
    Gazthesparky Member VCDS Map User
    217
    To remove the door cards on a A4 cab is quite easy
    1 open the door and gently from one side prise the tweeter grill off with a thin blunt object underneath there is a screw holding the tweeter housing on unscrew this and unplug
    2 get a long thin object like a knitting needle and look under the door pull Handel you should see a small hole slide the needle in and make sure it's vertical you should feel a clip this should release the buttons in the door arm unplugg the buttons there's a screw in there to undo
    3 From the hinge side of the door gently leaver the trim piece off as you get to the lock end of the door be careful because the last clip is T shaped and you need to gently slide it side to side to get it out under there is 4 screws remove these
    4 there's 1 screw in the middle of the bottom of the door if you look under the door you will see it
    5 gently pull the door card around the edge of the door once the clips are released lift the card up
    6 you will see the metal chord attached to the door opening leaver carefully unclip from the handle then you will have the wiring to the door card there will be a orange leaver on the plug lift this and the plug will come out of the door module
    To refit do that in reverse
  11. puterg0d
    puterg0d New Member
    Any updates as to what the speaker sizes are? I really don't want to start taking the car apart until I have the replacement speakers on hand.
    Thanks!
  12. Joe_Murphy21187
    1,060
    71
    Still no further with speaker sizes. Until I physically hold it in my hand, I don't think I will know for sure. I'm hoping for 8" (20cm) in the front and 5 1/4" (13cm) in the rear.
    Thanks to Gaz RE the front door panels, I'll whip one off when I get a free day and some consistent good weather!
    With regards to the proposed build, had a few changes of approach, mainly due to wanting more functionality from the HU. Thinking of a Pioneer double-din touchscreen unit now, between £300-£400 so cheaper than the RNS-E (even with £70 wiring adaptors), much better connectivity and better functionality. This gives proper pre-outs and a 4 channel amp (50w) in the HU itself. This would mean I could run new speaker cable from the HU to the rear channels & upgrade the front & rear speakers, whilst using the Subwoofer pre-out to feed my mono amp in the boot (situated in place of the x2 20w amp previously used for the rear speakers... when I find it), to power the square 6x9 subwoofer in a custom box though the ski-pass!
    The custom box will be made to have the 6x9 Vibe sub facing into the cabin:
    You might notice the larger 'face' of the box (where the woofer will be mounted), the idea being this is the last piece to be installed and will make the enclosure fixed (unless face removed). This could either be an additional 'face' layer JUST to hold it in place, (in which case would provide a recess for the driver), or it could actually be the front of the box (driver attached directly to it). Probably trim the main body of the box in grey carpet, and the face in black so it blends with the interior (sub face is white for contrast).
    Any thoughts on if this will/won't work??
    I'm 99% sure the stock boot amp will not have the required gauge wiring for a 700w amp, so new power wires and RCA leads (unless I can utilise the feed from the quadlock connector to feed the mono amp...?).
  13. puterg0d
    puterg0d New Member
    that looks like a nice design. I was thinking of doing something similar, but it wouldnt have been able to go up through the hole like that since I am using a 10" I already have on hand. Ultimately i decided that design would take up too much room in the trunk, so I build this (still searching for matching carpet):
  14. Joe_Murphy21187
    1,060
    71
    Nice job! Have you done much fiberglass work before? I'm weary of using it to be honest, even though I've heard it's simple if you take your time and do it right.
    The sub I have from a previous car is a 12", so I don't think I'd be able to get the enclosure size required (and possibly the driver) to fit into the space you've used. Also what I found really annoying about previous subwoofers is that it makes your boot lid rattle. Unlike chavs with corsas who think vibrating the the rear windscreen wiper off is cool, I didn't buy an Audi to be obnoxious! Dynamat may well solve this...
    I thought having the driver facing into the cabin would give better sound and also look the dog's dandies... Would love to see/hear your install when finished! What amp are you planning to use? How are you going to connect it etc??
  15. puterg0d
    puterg0d New Member
    Actually this was only my second fiberglass box. The first was in the Saab I just sold to my ex-wife (pic below). With that car I learned a lot that I carried over to this one - and learned even more this go round. It's really not hard to do, just a lot of prep work, and patience. It took me a week working on it in the evening after work.
    There is no way a 12 would fit in that spot - and the other side is even tighter (with the hydraulics and controls for the convertible top). It would be "possible", but would require some very creative thinking. I'm also not into the whole "booming" thing anymore, just want nice, full range, sound - and want it to be moderately loud and audible with the top down cruising down the highway, while still sounding good (distortion free, unlike the stock system).
    The sound is kinda subjective - unless it's crossed over kinda high - given the wave length of bass frequencies. However, it should have less issue of rattle in the passthrough, and therefore less dynomat requirement. It will definitely look tight, for sure.
    I am still on the fence about the rest, but the sub is a Fi Q. the amp will probably be the new Mmats 6150D (6x 150 - ch 5 and 6 can be bridged at 1ohm and 900+ WRMS). I plan to use the stock headunit, for now at least, and tap off the speaker wires coming from the headunit (in hopes to catch a full range signal). Haven't decided what I will use as the LOC though. If I can't get a full range signal from behind the HU, I will tap off of each main speaker lead and use the Audio Control DQL-8 for summing.
    This is the Saab's box (my first attempt at a fiberglass enclosure):
  16. Joe_Murphy21187
    1,060
    71
    Does anyone know if the stock Audi rear amp has a normal +12v ignition switched feed I can tap to turn on my amp with the ignition?? Or is it all coded using the VAGCOM system like the headunit??
  17. Joe_Murphy21187
    1,060
    71
    Right, well overdue on an update on this... but the good news is the subwoofer install is finished and working excellently :)
    Box:
    The original concept as above was changed slightly when I found that the height of the lip between the boot and the ski-pass hole was slightly less than the thickness of one sheet of MDF (15mm I think I used?). So instead of angling the ski pass section of the box upwards I used the base of the box in the boot as a mounting for the bottom of the ski pass section (glued and screwed down). Also managed to use the whole height of the ski pass section and make the box to fit the space.
    Rough measurements are:
    Boot Width = 89cm
    Boot height (max under movable top) = 26cm
    Depth of boot section to give approx 0.5cuft volume (internal) = 11.5cm
    Front face height (approx) = 35cm
    Ski pass section width = 23cm
    When I first fitted a sheet of MDF cut to the boot width, it became apparent that there was a curvature in both corners, so rather than try to cut the side panels in the boot, I angles both the front corners of the box, cutting half of a 4cm x 4cm square from each corner. As the base was 100% flat, all other sections were fixed to this.
    When it came to the front of the boot section (which sits next to the boot bulkhead), instead of having two pieces and a hole in the middle I decided to keep a strip at the top in the centre for strength (and practicality when lining things up). Again angling the corners, this time for strength as there would potentially be a lot of stress on that join. This meant that when I was making the sides of the ski-pass section the tops needed to be cut at a 45deg angle, which meant using a circular saw (as it’s the only thing I had which would cut at an angle). In the end this gave a really strong joint and the bigger surface area was good for sealing with glue.
    The rest of the box was pretty straight forward. Measure twice, cut once was the theory, but attempt the pieces in situ after each attempt to check I was still on the right track. A few corrections here and there but nothing major. Braced the box with some cheap soft wood which came in a long strip, not being cut by me I knew it would be at a right angle ;)
    The whole box was made using a jigsaw, circular saw for the 45deg cuts, hacksaw for those awkward to reach places, drill (for pre-drilling the screw holes), counter sunk screws and a substantial amount of PVA wood glue!
    Amp:
    The OEM headunit (Audi Navigation 5.0) doesn’t have a pre-out, which meant using a hi-low converter and tapping directly into the speaker wires. For those who don't know, the converter takes the high powered signal from the speaker wires and converts it to a low power signal in the form of RCA connections. The converter I got (importantly) also had an automatic remote turn on connection, which activates a low current 12v output to turn on the amp when an output to the speakers is detected. So far I have noticed no lag in the stereo turning on and the sub kicking in which is a big plus!
    Wiring was reasonably straight forward, standard battery lead through the bulkhead via a spare grommet and under the dash and tucked under the side trim. Same with the RCA & remote lead (opposite side of the car to avoid interference). One thing I decided to add was some red LEDs behind the driver (hence why you will see a double terminal post o the rear of the box). I hooked them up to the cigarette light feed because it was easy to get to, so that when the interior illumination is on (sidelights on) the subwoofer emits a subtle red glow. Some people may not like this but for the same reason I wanted a white sub not a black one is I want it to be noticeable as well as look neat and tidy.
    When the wires reached the rear seat bench I fed them under and then behind the back rests, and carefully fed them around the side of the roll-over bars and into the boot.
    Finishing Touches:
    To make the box looks as discrete as possible, I wanted to keep a rear grey carpet, and the front face black leather. Leather is pretty expensive however, and I was able to get hold of an 'off-cut' of leather effect material for £5! I could do another 3 boxes with the amount I have left though... I didn’t see any point in spending time in covering the sides no one will ever see, plus the box was made to fit exactly in the space available, so putting a few mm of carpet on a few surfaces might have made it a tricky fit. Carpet & leather both attached using spray glue and a few staples on the edges to stop it peeling.
    I secured the box in place using two 'L' shaped brackets which I cut down to size, and attached them to two of the bolts which were at the top of the ski pass tunnel. The middle of these three bolts was used as an earthing point for the amp.
    For anyone who has removed the rear armrest in an A4 cab, you will know that there is a relatively unpleasant hole where the seat belts go. Originally I thought about gluing foam to the face of the box and fixing the leather over it, but when it came to it I got a polystyrene block from work, trimmed it down and covered it in the same leather material. I them wedged it under the front face of the box as a sort of 'elbow-rest'. It’s not perfect, but it looks 100% better than having a hole! Perhaps a better solution to come in the future...
    Mounted the amp directly over the binding posts so it looks as neat as possible. Still need to create some sleeves from the same carpet to slide over the wires so they are less noticeable but haven’t got around to it yet.
    Well, below are the pics. Any questions or comments are welcomed! (Some pics are lower quality as these were taken using my phone)
    Top of ski-pass section:
    Driver tested for fit one final time:
    Fitted in the boot:
    Cable:
    The finished product!
    And at night...
    Hairless wonder, J@Y and Funky Dunky like this.
  18. t13rn
    t13rn New Member
    10
    Cracking install mate, nice and stealth. I have a 2007 cab to and am desperate to upgrade the speakers etc. Did you find out what size for definite the front speakers were? I want to look at an amp with components but don't really want to worry about mounting the crossovers etc as want it all to look OEM!
    I am not a master crafter like a couple of you here, nowhere that one can purchase a stealth boot sub enclosure?
  19. Joe_Murphy21187
    1,060
    71
    Apologies for the delayed reply, haven't checked this thread for a while! I never did find out for definate what size the speakers are. I had one of the rear quarters off when installing my smarttop controller, but stupidly I didn't measure the speakers whilst I was there.
    The rear speakers are either 10cm or 13.5cm, and the fronts are either 6.5" or 8". In the saloon/avant the door speakers are all 6.5", but because (this has never been confirmed but is highly likely) the cab doesn't have a subwoofer, the front door speaker could have been made larger to compensate, hence possibly 8".
    If you're putting aftermarket components in you will definately need to mount the crossovers, but this can be done behind the dash for the fronts, and in the rear quarters for the rear speakers. That way you'll only take the bass/mid cable through the door gromet and can run the tweeter cable behind the dash. Having gotten a little extra bass I haven't had enough inclination to start taking the doors/dash apart to upgrade the speakers... yet.
    If you do any upgrade be sure to post some pics and details of your findings!
  20. J@Y
    J@Y Would ya look at that!
    23
    That looks spot on, unfortunately I'm totally clueless at anything such as this so it's going to have to be somebody who does this kinda thing for a living to sort mine out!
  21. Joe_Murphy21187
    1,060
    71
    The trouble is fitting a 'normal' sub into the space available and also not losing most of the sound when the roof is off...
    If you don't have drawers under your seats you could look into under-seat subs, although I've never heard one in person. I used a hi-lo converter as my HU has no pre-outs, works well, although now I've found the amp in the boot (which powers the rear speakers, there is no sub as standard I believe), for the sub I would probably tab into these high level outputs and save soldering (crimping would've been sufficient but I like to know nothing is going to come adrift!) behind the dash.
    If I was a little less specific with the dimensions and didn't angle the corners (you'd lose a bit more boot space), I could make the enclosures to order! But taking into account the material costs and amount of time it would take me it just wouldn't be worth the effort.
    If you can find some cheap MDF, why not give it a try...
  22. Joe_Murphy21187
    1,060
    71
    Replaced the subwoofer today, after being repaired once and broken beyond reasonable repair by some passengers (kids) at the weekend, it was time to replace it. The marine version is discontinued so I ordered a pair of the standard black 6x9s instead. As they are the only square 6x9's on the market they were my only option! I also fitted the grille to avoid any future damage... even though I now have a spare :meeting:
    Plus point is the pair were about the same price as the single previously, downside is the LEDs are not visible through the cone. The LEDs would have needed re-gluing to the basket anyway so I just removed them and left the feed disconnected inside the enclosure. I actually quite like the black, it doesn't stand out as much as the white and nowhere near as much without the LEDs, but it's more 'stealth'. Before and after pics below:
    Hairless wonder likes this.
  23. J@Y
    23
    Pardon my ignorance but is that actually a sub? When I search for it they come back as a pair of 6x9's
  24. Joe_Murphy21187
    1,060
    71
    The replacement is part of a component 6x9 set, however the original was a 'subwoofer' as classed by the manufacturer. They were beefy for 6x9s and small for a sub, so I guess you could argue either way. It takes the strain off the door speakers in my cab though so it does the job and allows the stereo to go louder overall.
    Marine Subwoofer
  25. S17EVEB
    S17EVEB New Member
    Hi Joe, your design looks immense. Am I right in assuming now that you have a 6x9 type speaker (3 coaxial type) that you wouldn't need the carefully designed box? It could theoretically be open behind it? Cheers
  26. antony b
    antony b New Member
    O'rite guys,
    Speaking from experience with a 2007 A4 Cab non-bose, the whole thing can be a total nightmare... Unless you have the following info...
    Number 1...
    Front and rear speakers are 20cm's! Do not waste your time on 6.5" speakers cos you need 8"... Front are component with tweeters and 2 x 3" mids in the dash... I there is also another 3" in the mid of the dash, but I'm not arsed about changing that one out since it's used for speakerphone primarily.
    So in total at the front there are 7 speakers, 2 x 20cm, 3 x 3", and 2 x 3/4" or 1" tweeters in the doors.
    In the rear there are 2 x 20cm (8") coaxial speakers...
    First I was quoted silly bucks by a guy who wanted to just ignore the rear speakers, e.g. disconnect them, and install an amp and 2 component speakers for about £1400 with a pioneer double din touchscreen head unit...
    His stuff was good, and I wanted the pioneer at the start but couldn't justify the price and loathed the idea of losing the rear speakers. Soooooo I did the unthinkable... I went to halfords and said... "whatcha got m8"...
    Turns out they had last year's pioneer models something like this and I wanted the 2016 model, so I looked at the rest they had on offer... They had a reasonable looking SOny (a year ago it was more expensive) for £140 and they'd install it along with all the necessary extras for an additional £20 or £50... And trust me, the B7 cab needs all the bloody extras, everything that could be screwed up IS screwed up on it, antenna interface, steering controls, power, microphone, bleh bleh power block etc. basically it'll cost you another £60+ minimum for the interface, but they'd install it all for that price so... Sod it I did it... Even if I change out the radio in the future, I can keep the interface.
    The result?
    Absolutely banging... Initially I didn't like the sound at all, took me a while to figure it out... Basically all 4 x 8" speakers are considered subs, in order to get a decent balance, I need to set the fade to +11 on the rear, and then it balances up nicely with the front. Whilst I've been desperately seeking to improve the speakers, the sound even from the original speakers has improved drastically, + now I have BT, NFC, Spotify and a bunch of other bonuses to boot... Using google go with the radio is SAF, I press the button on the steering control and tell it to navigate to anywhere and it's spot on, open apps via voice e.g. spotify, obd link etc, all works a treat, and I don't regret not spending the money on the pioneer, the only bonus I'd have gotten with that was the option of a rear facing camera for more money, and I already have solid parking sensors.
    My advice is to save some cash, use halfords for a mid range double din, and take them up on the install... Then get some nice speakers (you may not even need them though... I'm just doing it cos I'm searching for perfection)...
    Repeat thought... They are 20cm! I wish someone would have bloody written it online earlier cos all the "find your speaker sizes" sites say to get 6.5", Wasted £140 cos of that advice... Cheers!
    Oh, and I can give some advice on removing the door panels and rear panels if needed... The central screw in the door handle has some kind of locktite on, and it's a complete c**t to get off... almost threaded the 30/40 torx screw as a result... Use a power drill or similar with an extension rod on the bit so you can get it into the right spot... The panel comes off easily enough, the rear is easier, don't worry about removing the rear head rests... F**king nightmare...
  27. antony b
    antony b New Member
    Bro, they're 8" front and back!
  28. antony b
    antony b New Member
    in the B7 cab, they're all 8" (20cm), think they're 2-3" in the dash, but the doors front and rear side are 8".
  29. antony b
    antony b New Member
    Can I just add, that the Sony I went for was a 55W head unit, that with the standard speakers is absolutely more than enough, I don't need an amp for my purposes, it goes as loud as you need it to, louder than my ears can cope with anyway, you'll be much happier than with the standard HU, which is a complete pile of **** imo since the upgrade.
  30. Joe_Murphy21187
    1,060
    71
    Sold the a4 can this weekend and will be selling the subwoofer installation in the classifieds shortly. If anyone is interested PM me, will be collection only due to size and weight!
