a4 b6 pcd and off set
fifer1981 Dec 18, 2008
  1. fifer1981
    fifer1981 Member
    33
    after a quick google i came up with this
    Make - AudiModel - A4Year - 94>PCD - 5x112Offset - 35 to 45Bore - 57.1
    does this sound correct for a b6 a4 tdi ?
    looking for some second hand wheels and need to know what sizes i can look at
    thanks alot you guys :salute:
  2. quattrojames
    14,068
    585
    Sorry just seen this.
    Yes that sounds about right, what does the 57.1 bit mean?
    Assuming you have a B6 you will be looking for 5 x 112 PCD with an offset of 42 or so.
  3. Davidwynne
    Davidwynne Landatec
    The 57.1mm is the diameter of the hole in the centre of the wheel. This has to match the hub assembly outside diameter. If the wheel has a bore diameter larger than 57.1mm then a spigot ring will be required to locate the wheel correctly.
