A4 B6 Avant - 4 x H7 bulbs?
DALE_AVANT Jan 23, 2012
  1. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    620
    21
    As title, looking to replace the main bulbs, and noticed two "extra" dome-like lenses.
    Are the 2 x H7 in there as well, therefore 4 required?
  2. simon.m
    simon.m Active Member
    2,747
    I no the dipped beam are h7 and then u have your full beam ones
  3. DALE_AVANT
    620
    21
    So four in total, with two only being used when on full beam/flash?
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    Two dipped beam and two full beam 4 altogether
  5. DALE_AVANT
    620
    21
    Thanks for the info Stu/Simon
  6. S.line
    S.line Active Member
    484
    I think the fogs are the same too?
  7. quattrojames
    14,050
    578
    Fogs are H11's.
  8. stu_m
    1,441
    No they are h11 :)
  9. DALE_AVANT
    620
    21
    Thanks for the replies guys.
    Are the lights in the bumper "driving lights" or "fog lights"?
  10. stu_m
    1,441
  11. DALE_AVANT
    620
    21
    From the quick look I had earlier, are the "dome" or "fish-eye" lights the normal driving dipped headlights?
    And the other "naked" bulbs are the full beams?
  12. quattrojames
    14,050
    578
    Yes. You could tell that by putting the lights on and walking around the front for a look!
    stu_m likes this.
  13. DALE_AVANT
    620
    21
    Indeed - that's exactly what I did!
    This is my first VAG, I've had almost exclusively Peugeot for the last ten years. On the Pugs I've had, the headlight bulb that is visible is usually the dipped and main beam, and there is is only 1 bulb per side.
    Hence me expecting that the normal driving lights would be the ones that I can see through the outer lense, and the "extra" 2 bulbs behind the dome would be the main beam of sorts.
    I'm up to speed now though, thanks for your info.
    To clarify for others that may stumble upon this thread:
    - Dipped normal driving lights - behind the domed "fish-eye" - H7.
    - Full beam - visible from outside of car - H7.
    - Fog lights - located in bumper - H11.
    - Side lights - ??
    - Indicators - ??
