Scanned after clearing all DTCs
VCDS-Lite Version: Release 1.0
Sunday, 15 January 2012, 22:58:00:0
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8E0 909 557
Component: 2.0L R4/5VS 0003
Coding: 0011501
Shop #: WSC 63351
1 Fault Found:
17701 - Map Controlled Engine Cooling Thermostat (F265): Short to Plus
P1293 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0010 0001
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
01333 - Door Control Module; Rear Left (J388)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Shop #: WSC 63351
No fault code found.
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 950 D
Component: KOMBI+WEGFAHRS. RB4 D14
Coding: 00400
Shop #: WSC 00001
WAUZZZ8E82A014675 AUZ6Z0A0145618
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
01337 - Interior Door Handle Illumination
49-00 - No Communications
01339 - Door Warning Light
Address 56: Radio Labels: 8E0-035-1xx-56.LBL
Controller: 8E0 035 186
Component: concert II GRO 0008
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
01042 - Control Module; Not Coded
35-00 - -
End --------------------------------------------------------------------------------------------------
Individual module scanned
Sunday, 15 January 2012, 23:01:23:0
Control Module Part Number: 8E0 959 433 AL
Component and/or Version: Komfortgerát T9F 0514
Software Coding: 07883
Work Shop Code: WSC 63351
Additional Info: 8E2959802B Tõrsteuer.FS BRM 4.11
Additional Info: 8E2959801B Tõrsteuer.BF BRM 4.11
14 Faults Found:
53-00 - Supply Voltage Too Low
01334 - Door Control Module; Rear Right (J398)
01338 - Signal; Doors Not Closed
01326 - Control Module for Multi-Function Steering Wheel (J453)
01332 - Door Control Module; Passenger Side (J387)
01351 - Communication Wire at/to Ground (GND)
37-10 - Faulty - Intermittent
01590 - Igniter for Battery Disconnect (N253)
35-00 - -
01595 - Tire Pressure Control Switch (E226)
35-00 - -
01597 - Drive Battery Pre-Charge Circuit
35-00 - -
01729 - Switch for Seat Height Rear Pass. Seat (E66); Down
08-10 - Control Limit Surpassed - Intermittent
00496 - Sensor for Vehicle Leveling; Front
00490 - Right Rear Vent Temperature Sensor (G406)
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
01371 - Alarm triggered by Door Contact Switch; Driver's Side
Any help on the matter is greatly appreciated
Grover
