A4 B6 1.9TDI - boost/starting issues - only in the rain???
Tim Woodman Nov 20, 2012
  1. Tim Woodman
    Tim Woodman New Member
    10
    Hi,
    has anybody come accross a similar problem like this. Earlier in the year I had the EGR valve replaced as car would stall and not restart on a wet day.
    Car has run fine for 3 months. Today (raining) really poor accelaration then suddenly kicks in lurching forward.
    I am assuming the issue is still rain related
    Any thoughts welcome
    Tim
  2. A7788
    A7788 Member
    162
    On a side note, how much did it cost to replace the EGR valve and out of interest why did you replace it and not just block it off or get a delete kit?
  3. Mike.M
    Mike.M Well-Known Member
    2,509
    170
    You must have a short somewhere.......and the rain must be arcing something
  4. Tim Woodman
    10
    It was about £250 from memory. To be honest I hadnt had the car long and didnt know about the other options, garage didnt mention it either. Is it a common problem with the EGR valves on the b6?
    Drove it again tonight without fault, obviously an intermittant issue.
  5. A7788
    A7788 Member
    162
    All EGR valves go wrong, doesn't matter on make of car unfortunately it just doesn't work for very long lol.
  6. Tim Woodman
    10
    any ideas where that short could be? Whole thing lacks power, I'm having to rev it like mad to get going then suddenly find your self flying off down the road. Not the safest way to drive!
  7. Tim Woodman
    10
    thanks i'll investigate the kit if it doesnt get any better. I assume it doesnt do any harm to bypass it?
  8. A7788
    A7788 Member
    162
    Should make it better, more responsive etc :) Blocking it off is the easiest way - or if you want it removed all together then get the EGR delete kit - Allard 1.9 TDI EGR Delete kit for VW Golf Mk 4 GT Tdi 130 + 150 | eBay
