A4 B6 1.9TDI Avant A/C Issues.
sabaxter Aug 4, 2013
  1. sabaxter
    sabaxter Active Member
    465
    27
    Good evening guys. Firstly I would like to apologise for further threads on A/C issues. But I've checked all the threads I have come across and still no avail.
    1) The A/C only gives out ambient temperature
    2) ECON light does go on and off
    3) I've had it re-gassed and the pressure is good.
    4) The clutch plate and bolt are in tact and therefor not missing.
    Ive had a good luck tonight and done some electrical testing. Both the fuses in the panel are fine. Im unsure of the relay location although I have a 267 that I got on ebay. Tonight I have done some voltage tests. There is a 14 pin plug on the NS of the engine bay I took a reading there and got just over 12V
    I took the plug of the A/C compressor and did a test there and got under 1V im confused at where the voltage is dropping. On the left fan there is a silver looking electrical box. Could it be this is faulty? Also on each side of the fan assembly there are sensors with yellow plugs, what are these?
    Any help is much appreciated but please can you keep it simple especially if your explaining electricals to me.
    Thank you all!
  2. quattrojames
    14,068
    585
    AC can be a pain, I know!
    Before you get too far, can you get the car scanned somewhere? It could be a simple sensor error or similar which will become immediately apparent.
  3. deano1978
    deano1978 different gear
    713
    81
    I hate mine. Did work in winter. Not working this summer. Be winter when its fixed.
    Think i need a new compressor pump :-(
    as james said above. Will get mine scanned to make sure.
