A4 B5 Pics thread.
PaulJC84 Feb 18, 2006
  1. Foxmeister
    Foxmeister Fired Up!
    1,785
    Nice mate, better when shiny thou?
    Did you fit the RS4 bumper yourself, how was it?
  2. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    nice i like ..........how much is that been dropped?
  3. diffas
    diffas Member
    152
    23
    Shiny is over rated :D It's my daily workdrive car so I don't have time or motivation clean it every night after work.
    I had light problems with fiting it on because I didn't have proper rs4 bumper holder at that time.
    So i did measuring on air and it wasn't that precise. It's still a bit in wrong size but with some 'stretching' it sits pretty good after all.
    Next time I know how it's done better. ;)
  4. hiltoa
    hiltoa VAG erfahren
    298
    About 3 feet from standard for a TDi!
    TBH I just built up the FKs so that the springs were under tension and then installed on the car - the rears have stayed as they were, and I raised the front by 25 threads(!) as it was scraping on lock. It now only scrapes if it's compressed under lock (ie hammering around a lumpy mini roundabout).
    I'll probably raise it a little more when I refresh the front arms as it's still a little too low for my taste, but the C arms are so fecked it may raise a few mm anyway when they are replaced!
    @diffas - it's very rare that mine looks as clean as it appears in the photos, a healthy covering of muck hides the scratches and corrosion pimples! :blush:
  5. tdia4
    tdia4 TDIPOWARRR
    613
    Hiltoa, sure i saw your car on Sunday at Cars in the park(harewood house)
  6. hiltoa
    hiltoa VAG erfahren
    298
    Sounds perfectly feasible! :yes:
  7. mat_vw
    mat_vw Member
    31
    Thanks, Glade it has given you the solution to your door card problem,
    The wheels are not TT Comps, same design just et35 and 5x112 instead of 5x100 so not as common as TT, they came off Audi A6 4.2 C5
  8. Keithsri
    Keithsri Member
    33
    Here's some pics of mine,at the beginning,and now. i lamin x'd the headlights,and did alot of other small touch;s,il explain some other day lol.. i like it,prob will lower more aafter mot this week... lemme know what you think..........
    at the beginning:
    At the minute..
  9. Foxmeister
    1,785
    Turned out nice Keith, like it mate. Wot suspension are you using, sits quite low?
  10. Jason.s
    Jason.s Active Member
    2,879
    348
    Two quick ones of mine after a wash today
  11. mad cornish pastie
    mad cornish pastie Audi novice handle with care
    81
    got to say i'm impressed with it...
    not bad for the sum of £700 with 11 months mot
  12. 205man
    205man Active Member
    1,072
    14
    few pics with new springs fitted and bit of a shine lol
  13. diffas
    diffas Member
    152
    23
    My baby got new shoes. :)
  14. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    That is a seriously hot car mate! I am seriously considering a B5 when my B6 dies, which is inevitable with my wife driving it more than I do now. I am loving them wheels!!
  15. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Very nice stance ! What alloys are these, rial daytona's ?
  16. Sulli79
    Sulli79 Active Member
    541
    37
    Here's mine. Need a clean though!
  17. rasA4
    3,287
    119
    lovin the recaro's :)
  18. sam4191
    sam4191 If In doubt, Flat out!
    417
    With A8 18" wheels. Please ignore bonnet...needs paint, and bent front number plate! lol![​IMG]
  19. tdia4
    tdia4 TDIPOWARRR
    613
    What are the rear lights you have on your a4 Sam? They look nice.
  20. sam4191
    417
    They are led lights from Germany, no idea of any names or anything.
  21. pjw
    pjw Member Audi A4
    222
    Only just got it, but heres a quick one of mine.
    Plans are alloys refurb and putting to Anthracite, and if i can find the paint to match a pair of better skirts.
  22. 2thumbs
    2thumbs New Member
    19
    Here's mine:
    SE 2.4 V6 in Santorin Blue Pearl. 154k on the clock and the interior smells of Vanillaroma Magic Tree's!
    Engine and gear box are sweet, sounds quite nice although maybe a bit too quiet but I'm happy for now.
    Had new discs, pads, bearings and ABS sensors all round less than 2000 miles ago.
    So far I have:
    * Fixed the glove box light. Thought the bulb was blown, but it just wasn't connected to the loom. Also sort out the badly fitted glove box at the same time.
    * Fitted Bosch AeroTwin flat wiper blades
    * Fitted a carbon coated pollen filter as the air flow was ****, so expected the old one to be past it, perfect now.
    * Fitted a new fuel filter.
    * Replaced the power steering fluid.
    * Bought 5w40 oil, a gen. oil filter, sump plugs, spark plugs, HT leads and coolant temp sensor all ready to go in/on.
    What I need to do:
    * Remove both front seats in the hope of sorting out the air bag light. Also f' knows what's living under there so a hoovering is required.
    * Sort out the instrument display as it has 'cluster pox'
    * Replace both registration plates as they look as old as the car and let it down cosmetically.
    * Check the plenum chamber drainage holes
    * Paint the aerial as it's currently a chavvy silver. Going satin black.
    * Get the original stereo recoded
    * Buy 3 litres of Motul Gear 300 oil for a gearbox oil change.
    * Possibly debadge it.
    * Possibly put coilovers on it.
    It's got a mostly full service history and nearly all the old MOT's, even the old'ns that used to be on A5's pieces of paper! Nostalgia.
    I found an invoice from the Audi dealer dated 2002 for £1800 that included a new clutch kit, flywheel rear brake calipers, discs and pads. Shocking tbh.
  23. pjw
    pjw Member Audi A4
    222
    Is the airbag light a common problem? Whats usually the fix? I havent put vagcom on mine yet but im hoping its just the connectors..
  24. 2thumbs
    2thumbs New Member
    19
    Dry joint under the seats.
    The vag-com will reset the light, but without fixing the problem it's highly likely to just come back on again.
  25. diffas
    diffas Member
    152
    23
    Sorry for very slow reply. I'm not that active reader on this forum. :) Those are Rial Nogaro Black. 9x18: front with ET37 and rear ET30.
    I'm waiting to get my new coilover set to be installed. I'm acrophobic u see. :D
  26. adamss24
    4,584
    407
    They look the dogs ******** mate ! Had a set of rial daytona race split rims (sold them a few weeks ago) and i regret it ever since. I have just bought a set of a8 parabols (aka fat fives !) and i will just keep them as summer wheels for the b5 quattro. For the allroad i have the stock 17" Ronal split rims for the winter and 18" ABT sportysline for the summer...just bought another set as i could not been bothered to refurbish the set i allready had !
  27. Connor_scotland
    Connor_scotland Member
    Only got this last week but i like it so far
    The only snaps i have of her
    S4 kit
    19" RS6 rims
    Lowered
    Heated mirors and all that milarky
  28. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Tidy Avant mate. If I were you I would get rid of those headlight "brows". Make it look much better! So is this your run-around as I'm taking it you have a scooby too?
  29. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Very nice and welcome to ASN.. Sorry No to the eyebrows
  30. Broken Byzan
    13,237
    465
    Fastest colour too.
    I cannot see the S4 kit though? Are these early photots?
  31. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    No s4 kit there. Looks kind of like the votex kit but deeper at the front anyway.
  32. dest
    dest Member
    193
  33. Foxmeister
    1,785
    Lovely car mate, saw it on SRS, looks spot on with the B6's!
  34. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    Finally got round to getting a pic of the car after fitting new 17" wheels and some FK springs :photo:
    Looks a whole lot better than before, both in lack of corrosion on wheels and the car sitting level (and a bit lower) :arco:
    Before;
    After;
    If you're wondering what the white stuff below the rear door is, it's soap suds from the jet wash that I didn't rinse off properly :keule:
  35. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    Did a clean and a polish yesterday and took one pic.
    Here it is.
  36. sk8xtrm
    sk8xtrm New Member
    14
    Some gorgeous looking cars on here J
    im new so thought I would post up quickly with a few pictures of my car, it’s an early 1.8t.
    [FONT=&quot][/FONT]
  37. AndyC
    AndyC Moderator Staff Member Moderator
    719
    Very nice............ think this will be my route
  38. nwmlarge
    nwmlarge flat out
    219
    nice votex kit! subtle differences for the early ones on the skirts!
  39. eoeumc
    eoeumc Member
    118
    Hi guys :)
    Just put some pics on the PC so thought I would share now :sly: Needs a bit of tlc to the body work, dents scratches etc :(
    Its a bit dirty but hey ho!
    Got plans for it, just need to sell my Escort (in signature) so I can fund them :banghead:
    I will be after decent black head lights and black led (maybe) tail lights and a lovely set of chrome tipped deep dish alloys. 18 or 19" depends on what I can afford. oh and a set of coil overs.
    Then maybe an ECU check up :ninja: lol
  40. ScottD3
    15,162
    1,123
    Bored in work so thought i'd pop out and take some pics of the car.
    its a bit dirty from the past week commuting, so will have to clean it again and take some better pics.
    Nothing great but worth sharing.
