A4 B5 Front ABS/speed sensor.
Lee Goodall May 26, 2010
  1. Lee Goodall
    Lee Goodall Active Member
    2,279
    Does anybody have a part number for the front ABS/speed sensor for a '97 A4 B5?
    Is it just me or does VAGCAT never work anymore?!?
  2. aragorn
    18,438
    845
    Vagcats been dead for a while now.
    8d0927803 is the current number.
    You got a faulty sensor?
  3. Lee Goodall
    2,279
    Nice one. Thanks mate.
    I replaced the CV joints but one side got stuck in the hub and required a fair bit of persuasion to remove. Now I'm getting a fault code for the sensor on that wheel.. I know the reluctor ring thing is ok as it's brand new.
    It was funny because I had the traction control turned on and it kept applying the brakes at 2K revs lol.
  4. aragorn
    18,438
    845
    There might be a spare laying around here somewhere.
  5. Lee Goodall
    2,279
  6. aragorn
    18,438
    845
    mind and get a new copper sleeve, your old one will probably come out in bits.
  7. Lee Goodall
    2,279
    There's always something!! Do you know where I can get one from?
  8. aragorn
    18,438
    845
    Allgermanparts will do you one, they're about 7 quid.
  9. Lee Goodall
    2,279
    Threy don't seem to be featured in their online shop so I'll give them a ring when I finish work. Cheers mate.
  10. Broken Byzan
    13,237
    465
    The ones in there should be fine, they were well greased up when they were fitted so should come out intact TBH
  11. Lee Goodall
    2,279
    I love working on your old car.. anything that bolts together is greased up nicely. The top arms on the suspension (including the track rod) only took a couple of minutes to take apart :icon_thumright:
  12. 27litres
    27litres Love My Quattro
    20
    The old version of VAGCAT is rooted. Try this: VAGCATMK2
    Does anyone know how to get that ABS sensor out of the actaul hub assembly?
    I'm gonna get the wheel bearings done, but need to remove the whole hub from the car and take it to my mech's workshop for the press. They look like they'll just pull through the hollow?
    cheers
    Marty
  13. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I don't think the hole is tapered so worse case it the top come off and you pres the guts out into the bearing space
  14. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    14
    follow the wiring it plugs in just inside inner arch, you can remove hub carrier and leave sensor in hub if you unplug it
    if you really want to remove it try twisting side to side first to loosen it
  15. 27litres
    20
    Yeah, I found that plug this arvo! Wasn't too easy on mine though - 1 glovebox removed to find wire!!
    The sensor came out of the hub easy enough, it was the carrier I was referring to when I said assembly!
    Once I knew about the plug, I realised the sensor won't fit through the hollow of the carrier!
    Cheers though
