A4 B5 - Can I run a sub and amp off my Symphony?
Dans-first-Audi
Hello all.
What is the standard head unit like? I want to keep an OE look can I run a aftermarket sub and amplifier using the standard head unit?
Thanks.
Yes certainly. You can even pick up the the rear pre-outs and remote on for the sub amp from the feeble little amp bolted to the left rear deck speaker, so the only additional wiring you need to run is a fused power cable from the battery. Easiest way through the bulkhead is via the ECU cover underneath the drivers wiper scuttle.n This drops down into the drivers footwell. There is a bolt at the back you can't get to but releasing all the others will allow you to prise up the cover enough to feed the cable through.
811
10
Jay
852
