A4 B5 Avant Rear speakers / amp
JayB5UK
Deal, Kent
Hi, got my Avant on Friday, faded stereo to rear, nothing!
I'm unsure if there are any speakers at all for a start but gather that the rears are fed off an amp like the saloons.
Anyone got a pic of where to look etc please? Then I can figure if it's there, or faulty or what!
Cheers.
Mate, try taking the door panels off, when i bought my avant my left front speaker wasnt working, turns out it was disconnected for some reason.
Panels are easy to take off, rears you have one screw in each top corner,one in the grab handle, then take lower plastic bit off the handle (the lower plastic bit is wedged in proper) then you'll see another screw behind there, then on the window winder prise up the plastic insert then remove screw and pull winder off.
Then lift panel upwards carefully and thats it..:)
If theres no rear speakers then maybe previous owner upgraded the speakers and then took em out before selling and not replaced with standard ones..:tocktock:
Haven't had time to remove the door cards yet, but, I think the amp/sub unit is still there, from what I can see throught the hole and by pulling the panel aperture slightly and looking further forwards.
What is most likely, the pre-outs are disconnected behind the HU - Symphony, or is there some way of disabling the pre-out outputs from the Headunit? I can't imagine that the amp unit has become disconnected somehow.
Also, if I need to check, how does the HU come out for inspection behind?
Cheers, front speakers onlt is getting a bit depressing!
Chances are it's just disconnected from the HU. What tends to happen is previous owner fits an aftermarket system, tucks the Audi pre-out cable out of the way behind the dash, then in a hurry refits the stock unit come sale time and forgets to reattach it.
Cheers, looking a bit closer earlier I could see where the slots are by the buttons. Halfords the best bet to get hold of some keys quickly or ebay better for cheapness?
I'll probably end up uprgrading the system eventually but for now I need more than 2 speakers!
Mine's got the Symhphony in it, the holes are horizontal, think the Concert in my saloon had vertical holes which the seller has different ones listed.?
The keys are the same, you just need more of them for the Symphony. I wouldn't recommend you use the keys to pull the unit out, you'd be better removing the glovebox and pushing from behind.
If you don't latch the keys corretly (easily done), then pull on them you can easily knacker the spring clips and jam the unit there.
Is it easy to push out then from in there?
There are 2 types of keys as I can see, one seller on ebay quotes one lot for Horizontal slots and another for Vertical?
You seem to know your Audi Ice though AndyMac so willing to be faithful.
Sorry just reread my post, you still need the keys to release the clips, what I meant was don't pull on the keys to pull the HU out. Push it out from behind once the keys are engaged.
Sorry I didn't make that clear.
Ah, yeah makes sense mate! I must get a manual to see how to dismantle interior parts without ruining it. Nothing like making a nice solid car rattle like a ****** Peugeot eh?!
My 5 series was the last thing I did an ICE install in, it was a mission and a half getting the glove box out feeding RCA's through. Will probably wimp out of doing it to the Audi until spring now, but need to sort this out and at least change the standard speakers soon.
