A4 Avant towbar fitting woe.....URGENT
S4_dan Sep 20, 2013
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,716
    162
    Hi guys,
    Half way through fitting my new towbar onto the Avant and hit a bit of an issue. I've removed the old inner bumper bar, but when I slide in the new Bosal tow bar it's too long! It hits a plastic bung/plate that has been sealed inside the tube/tunnel that the bar slides into.
    It's definitely the right towbar judging by part numbers etc.
    Do I have to remove the plastic bung/plate thing? Surely that is there to prevent water running right through the tube/tunnel?
    Also, Are these Audi's partially pre-wired for the electrics? I can't find any 'surplus' wires to join to.
    Cheers,
    Dan
  2. bradh
    bradh Active Member VCDS Map User
    566
    58
    I can't help with this but do u have to cut ur bumper to fit the tow bar any chance of a couple of pics as I want to get one fitted so I can carry bikes in tow bar mounted rack
  3. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    AFAIK Audi only do 2 types of pre-wiring for options not fitted at the factory:
    - heated door mirrors
    - satellite radio on US cars
  4. S4_dan
    2,716
    162
    I've managed to join into the original lamp wiring, all ok now. Cheers.
    Mine is a Swan Neck towbar, so not sure if you can get bike racks for them?
    Yes there is a small cut required but it's not visible. Will take pics as i go along.
    Cheers.
  5. S4_dan
    2,716
    162
    Towbar is now on the car. The plastic plates need to be removed for fitting of this Bosal towbar (034601) as this particular towbar is for B6 & B7 platforms.
    Dan
  6. bradh
    566
    58
    If u could take a pic of the cut that would be awesome cheers
  7. S4_dan
    2,716
    162
    I forgot to take a pic i'm afraid. Will get underneath with the camera today and get a snap-shop.
    The cut out area was 2" x 1.5"..... at the very bottom of the valance. The cut is invisible and small. It is just the base of the neck that fouls the valance base.
    Dan
  8. Scott0583
    Scott0583 Member
    55
    Sorry for a thread resurrection, I bought a B7 removable tow bar that's brand new from eBay made by PCT Automotive. I had the same issue with the bar not going in. The non-removable towbar has the same part number for the towbar for B6 & B7, however they are different for the removeable one.
    Has anyone else had further issues as S4_dan has?
  9. S4_dan
    2,716
    162
    I remember my fixed towbar covered both B6 and B7. It was some plastic plates inside the tunnelling where the towbar frame sits in. I just cut out and never had any problems. I did seal around the tunnel exit about a year after fitting with sealant as I had to remove my bumper to carry out some work. It was only as a precaution not because they was any issues.
