A4 Avant - Nozzle Jet Adjustment - Any tips?
DelBoyUK Oct 19, 2013
  1. DelBoyUK
    DelBoyUK Member
    55
    Hi all
    The nozzle on my 06 A4 avant was blocked, so I duly pulled off the nozzle and cleaned it.
    It now squirts but no matter which way I point it, it seems to hit the inside of that plastic cover.
    The nozzle I have is the single jet (like this picture I found) http://img849.imageshack.us/img849/9536/gedc0992z.jpg but with the two hole washer jet cover.
    Also when the wiper is moving (with the little black cover off), the nozzle doesnt move with the wiper arm. Is this correct? So if pointing up, it stays pointing up all the time.
    Any tips for putting it in the right place?
  2. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,707
    557
    Use a pin and move test move test until happy that's what I did.
  3. Mike_B
    Mike_B Active Member
    533
    47
  4. seandom
    seandom Active Member
    136
    25
    I have a 56 plate Avant and my jet is the same as Mike-B's
  5. rizzini7
    rizzini7 Active Member VCDS Map User
    983
    156
    43
    Same here
  6. Mike_B
    533
    47
    If it helps, I had to replace the rear wiper arm today - the jet locates in a u shaped bracket which is what stops it turning.
    Then the cover (with the two holes aligned to the jets) goes over the top. Hope this helps - Mike.
