A4 Avant broekn rear springs - hard to find quattro parts ?
RogerTDI Jun 23, 2009
  1. RogerTDI
    RogerTDI New Member
    22
    I noticed a half turn of my rear spring had snapped of my A4 2000 2.5 TDI Quattro AVANT, I'm finding it hard to locate the quattro rear springs - any thought - might even take a breakers one. I don't feel like lowering the car just a standard spring should do, any adviced and can you use standard coil 12" compressors to remove OK. Much Appreciated Roger Opps update just tried eurocarparts and they seem to have them for £40 so might do that.
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    ah, the famous "Saxo" lowering kit! chop the other one for maximum slam!!
  3. aragorn
    18,135
    764
    You might find the ECP springs will make the car sit funny if its got the sport suspension on it already (which being a quattro it might well do)
    I know most aftermarket spring manufacturers dont generally provide springs for cars with any kind of factory lowering options. My brother had a hard time with his E30 BMW because of this. He had a 318iS which is fitted with BMW's sport suspension from the factory, which lowers it a small amount and adds bilstein dampers. He baught a rear spring from the factors for a 318iS but it was about an inch higher than the old one, and made the car sit all cocklegged. Factors said that was all that was listed in their book and that they dont do springs for factory lowering options, even though ALL 318iS's are lowered from the factory...
    If you dont want to lower it at all then i guess its the only option, so give it a try and report back on what you find!
  4. Siena
    Siena Active Member
    2,626
    I'd buy the ECP springs ONLY as a pair.
  5. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    If i remember right, they're on ly about 6070 quid from Audi. More than 40 but you know you're getting the real deal?... Right Sienna ;O)
  6. aragorn
    18,135
    764
    yer, but £140 for a pair means you may as well just fit an eibach pro-kit ;P
  7. Adam-D
    Adam-D Member
    457
    if its any help i have a full std suspension kit if you need it.
  8. aragorn
    18,135
    764
    Adam: Isnt your car a FWD? the shocks and springs are different on the rear of a quattro if so.
  9. RogerTDI
    RogerTDI New Member
    22
    Thanks for the advice everyone - I've been in touch with Adam, mines a quattro 2.5 diesel, if its a 2WD I'm sure rear springs ain't the same as thats the problem in trying to find the new. I'm not that interested in lowering as where I park is very bumby and underside scuffs etc. So two eurocarparts for £40 each unless i can get a breaking quattro... I might be intersted is some super adjustable rear suspension as i have a towbar and occasionally pull a car trailor... hence strong springs or why mine broke !
  10. dsmclark40v
    dsmclark40v Member
    744
    I will have 1 rear spring avalible soon, my cars a saloon though so it might be compleatly different but its a quattro sport
  11. PW-Motorsport
    PW-Motorsport Member
    396
    The rear springs on quattro A4 S4 and RS4`s are a know weak point.
    To identify the correct spring you will need the paint markings from the springs as there are loads (15+)of variations. They are all priced at £64.18
    The PR numbers will also help.
