A4 Aircon Nightmare?
steve5s May 19, 2005
  1. steve5s
    steve5s New Member
    23
    Hi hope you guys can comment on this:
    I’ve a 98 A4 (110 TDI Avant). The other week I noticed that the aircon had stopped working. Not only had the compressor belt broken, it had melted!
    I took the car to my local Audi independent, who advised that the clutch on the compressor appeared to have seized and also advised I also had the cam belt replaced at the same time.
    So he took the work on. The saga so far, the compressor clutch and the compressor have been replaced & still no working aircon. I’m told now that when the compressor failed, a voltage surge took out the relay and then the main aircon controller within the dashboard.
    How does this sound to you? I’m currently at £1240 & I still have the original problem, no AC /ubbthreads/images/graemlins/cry.gif
  2. imported_disley
    imported_disley Guest
    /ubbthreads/images/graemlins/shocked2.gif £1240 /ubbthreads/images/graemlins/shocked2.gif
    sounds like your pants have been pulled down to me!!
  3. ajmackie
    ajmackie Member
    922
    sounds doubtful really.
    a relay is a switch which is controlled by another circuit. ie the controller prob operates on 5v or 12v and this voltage goes through the relay to earth. as it goes through the relay, it switches the other circuit on which draws a lot more current.
    sounds doubtful personally. £1240 sounds a lot of money, basically £1000 to replace the compressor and a belt.
  4. steve5s
    steve5s New Member
    23
    Thanks mate that was my gut feeling.
    He said he will look for a used aircon controller, but he cant get one at the moment. He said the car can be collected. I would need to pay with visa. Does anyone know how I legally stand with this, if after replacing the controller the AC still does not work?
  5. MattS5
    MattS5 Active Member
    617
    59
    I would suggest that if you took the car in for a specific fault to be cured and parts were fitted that did not cure the fault, you should not have to pay for the parts as the diagnosis was incorrect.
    That is not a legal opinion of course. Why not contact your local Citizen's Advice Bureau for their take on the situation?
  6. AndyMac
    9,832
    45
    Ouchhh! What's he been doing? buying the parts from Audi? (Audi don't make any of the A/C components).
    I've every major a/c component on my A4 replaced by an aircon specialist and it didn't add up to that much. That was compressor, dryer, heat exchanger/condenser, all at different times and all requiring a regas each time. It cam to about £1k all told but each regas was £70.
    Sounds expensive even if the specialist solved the problem. My VAG specialist doesn't do A/C work so recommended the aircon guy. this makes sense as my Audi dealer was hopeless when it came to the first problem I had with a leak.
    It might be wise to get an A/C specialist to give you an estimate
  7. MattS5
    617
    59
    Be wary, all successful con men sound convincing!
    The last letter denotes the finish (usually black) or whether it incorporates Sat Nav and/or radio.
    For a used unit try http://www.4ringspares.co.uk/
  8. steve5s
    steve5s New Member
    23
    ...Heck, thanks mate. I'm between a rock & a hard place /ubbthreads/images/graemlins/crazy.gif
  9. MattS5
    617
    59
    I really would take yours to an A/C specialist for a second opinion and estimate. They're dealing with A/C all the time, your Audi chap may only come a problem once in a blue moon - best of luck!
