Most re-gass places are "no charge no charge". So if your system doesn't hold gass (charge) they won't charge you -even Kwik Fit do that so they'll answer your leak/no leak/does it just need a regass question for free.
If you need a compressor then you can buy new for around £190 or expect £50-£90 on eBay scrappy prices. If you swap compressor swap the orifice tube filter also as a minimum (which is held within the silver high pressure lines on the top left of the engine bay where the inlet valves are (like a bike tyre). Crack the nut on the left side line, orifice filter's in there ready to pull out). £10 new on eBay. If you go to an independent expect to pay around £500-600 all in for a new compressor and regass.
If you take the serpentine belt off the pulleys (front of engine behind radiator), very bottom right pulley as you look down standing in front of the engine is your ac compressor. If it spins freely (after removing the belt) in both directions your compressor has seized and is kaput fo' shizzle. If you feel the pulley moving the compressor innards inside -compressor should be OK.
Don't just recharge the air con with refrigerant, get the full service, because after you've opened the system (to swap the compressor and filter) you need to get a vacuum on the system for at least 30 minutes to get the moisture and old oil out. ATS/Halfords/Kwik fit will do that for you, and replace with fresh oil (wich circulates in the system) to OEM spec.
If you open the system -many will tell you to replace the drier too. In my experience it's not required IF you get the system under vacuum during regass to remove the moisture (that;s what your drier does -remove system moisture).
Best regass deal at the moment is £28 ATS on Groupon. All the others are £49.
Try and get the OEM part number from the sticker on your compressor and search eBay like for like -if you go the scrappy route. You can use the below PN bible which will show you which PN's are compatible with whichever you have on yours. Do not deviate from this. I learnt the hard way.
http://www.kosser.net/sites/default/files/deac13-0001_0.pdf
Simply press CTLR+F to search for your PN and cross ref to see what's the dealio. Then search eBay for the PN's which are going to fit.
Swapping the compressor is easy. 25 minutes. Undertray off. Serpentine belt off. 3 bolts to release compressor, drop the compressor onto a support (jack stand or something). Take off the two pressure lines (one bolt each). Replace. Then off to ATS of wherever for a regass.
Best wishes for a chill summer.
