a4 Advant 1.8t (NEW TURBO!) Help me plz!
rwellfair Apr 21, 2011
  1. rwellfair
    rwellfair Member
    96
    Hi there i have a 2004 audi a4 advant 1.8t s line not quattro,
    after may stops at the garage for a serging/wavey ride at higher revs they came to the fault as the turbo and said i need a new one, audi price £900 for a re con fitted!
    i cant help but feel this is way to much? iv been told by "friends" fitting is and easy 1/2 - 1 day and parts can be around £200-300 not the £600 odd re con price i got from audi and they said £750ish new!
    does anyoen know what part i need for my car or any other tips?
    Thanks Alot!
    Richard
  2. Chris79
    Chris79 On my 3rd A4! RS4 next???
    159
    Hi Richard,
    You'll need the part number from the current turbo or Audi to tell you from you chassis number (checking the unit will be easier)
    We had the same thing on our 130tdi golf. I bought a re-cored turbo from turbo active, cost about £400, so new core and old shells that had been cleaned up - looked like new.
    Then I asked a local garage to fit as the turbo is behind the engine in the golf - fitting cost £150 including oil.
    I'd say possible to DIY on an A4 but maybe get a quote first!
    Chris
  3. simon.m
    simon.m Active Member
    2,747
    give theses guys a try Prestige Engine Products <sales@prestigeengine.co.uk or tell 01905 792211
  4. hades-
    9,482
    646
    take the turbo off
    send it either to turbo dynamics AET etc etc
    and have them recon it
    will range between 250 and 450 depending on why its gone !
    if it has gone
  5. rwellfair
    rwellfair Member
    96
    thanks so much for your help! just for my info were is the turbo and how can i find teh number?!! im a plasterer not a car man! here is a pic attached of my car
  6. rwellfair
    rwellfair Member
    96
  7. Chris79
    159
    Look down the lefthand (drives) side of the engine.
    Part number should be on a flat part of the cold side which is the silver bit.
    Good luck!
    Chris
  8. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Thank you for making me smile at 07.30 :applaus:
  9. rwellfair
    rwellfair Member
    96
    here she is? what number is it?
    EDIT I've removed the image. Do you really want your chassis number on display on the internet....?
  10. hades-
    9,482
    646
    thats your vin number
    as above look on drivers side [​IMG]
    when you find turbo look more to the front of car for part number
  11. rwellfair
    rwellfair Member
    96
    ah thanks i let you know how i get on! audi said re con will cost me £650 odd yet i look on ebay and the prices range from £180-£400?!
    are they trying to rob me
  12. hades-
    9,482
    646
    dont get from ebay
    send it off to a good turbo shop
    turbo dynamics
    AET
    etc etc
    theres loads they will pick it up and redeliver it
  13. quattrojames
    14,068
    585
    Whether they're trying to rob you depends on your interpretation of dealer pricing. As all things you get what you pay for, audi will give a two year warranty I expect.
  14. rwellfair
    rwellfair Member
    96
    well the garage is not audi it just sells audi and seat/vw , but i understand you get what you pay for. any how had a look! is this the number onthe brass section? sorry really not my field
  15. simon.m
    2,747
    ok thats your cat box me thinks the turbo looks like a snale shel if that helps up a bit more from the last pic
  16. Broken Byzan
    13,244
    468
    Turbo is a bit further forward
  17. rwellfair
    rwellfair Member
    96
    thanks were getting closer!
  18. rwellfair
    rwellfair Member
    96
    is this is!
  19. rwellfair
    rwellfair Member
    96
    and were will the number be?????????
  20. Chris79
    159
    Not sure if this picture will work (iphone and tapatalk) but it shows the flat on the cold side with the info on.
    Chris
  21. rwellfair
    rwellfair Member
    96
    i think that was it in my last pic! is this DIY to remove or should a garage do this?
  22. hades-
    9,482
    646
    to be honest id get a garage to take it off and refit
    reason i say this is that you couldnt find it no offence but you say ya not a spanner man
    have it removed you send it off to get it recon will be cheaper then get them to refit also get a new oil feed pipe
  23. rwellfair
    rwellfair Member
    96
    kool well there is a mobile ma who may pop in to remove for me, thansk for all your help!
  24. rwellfair
    rwellfair Member
    96
    iv been told that the turbo never goes on my car, and that they have got ti wrong, serging problems linked to a turbo would be clear not just at high revs? getting a second option 2moro!
