a4 3.0 tdi s-line avant tyre pressures
aldo286 Jan 4, 2007
  1. aldo286
    aldo286 Member
    86
    help! my a4 3.0tdi came with 17" alloys on it but i have changed them too rs6 18" but dont know what the correct pressures are , as the pressures on the door pillar are for 16"or17" not a mention of 18" thanks in advance aldo286
  2. 1210tech
    1210tech Four Ring Fanatic Team Daytona Team V6 Audi A6 Audi Avant Owner Group S-line owners group
    696
    hi, i have the 2.5tdi engine (albeit in a B6 chassis) and i have upgraded to 18" rs6 with 225/40/18 tyres.
    the fronts i pump up to between 40 - 43psi and the rears between 36 - 40psi
  3. aldo286
    aldo286 Member
    86
    thanks 1210tech i am running them at 36psi at the moment will try what u have suggested , how many miles have you done ,do they seem to be wearing ok, aldo286
  4. 1210tech
    696
    yeah, haven't noticed any un-even wear at the moment but have only done approx 5k on them so far
    when i had my 17's on with 214/45/17 tyres i noticed that if i put anything less than 40psi in the front they would wear unevenly on the shoulders
  5. rodenal
    rodenal Active Member
    1,992
    Whoa 43psi is too high on 18" tyres.
    You should be running on 36-38psi
  6. Teutonic_Tamer
    Teutonic_Tamer GreasedMonkey HoofHearted
    122
    :no: Where on earth did you get that useless and factually incorrect drivel from? :no: :rtfm: :gun2:
    For the OP, and others in a similar situation who size up their wheels and tyres beyond the spec on the door pillar sticker - compare the the load index (something like 95) of the previous tyre you had, along with the load index of your new tyre. If they are identical, then identical pressures should be a starting point. Bear in mind that lower profile tyres generally require a small increase in pressures, maybe 2-4psi, when compared to the next higher profile. You are perfectly free to experiment with tyre pressures, to "tune" them to your personal driving style, but never go more than about 3psi below recommended figures.
