A4 2006 B7 2L Turbo
doushkaAudi Dec 3, 2013
  1. doushkaAudi
    doushkaAudi New Member
    Hi guys, joined the forum to gain knoweledge hope this going to be fruitful visit, thanks in advance.
    I bought a Blackvue 550 & Power Pro and would like to know which fuse connections to make in the fuse box. Like which ones are permanantly live etc. I have some instructions on installation but these are not quite specific enough. Need some pointers please.
    So the bottom line is can anyone help and give me instructions with pics on how to connect the PMPP to the fuse box.
    I have also got the "Add a circuit" connectors.
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,183
    2,662
    Welcome to the forum; hope you enjoy it here.
    Hopefully someone will be along shortly to answer your question. Sorry I can't; if you hang around here long enough, you may come to understand why I should never be allowed anywhere near a car's electrical system! :beerchug:
  3. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    767
    Mine is connected to the feed for the aux socket in the boot.
  4. jdp1962
    8,183
    2,662
    Mine (a DR380) is connected using the plug-terminated lead to a 12v socket concealed under the dash.
    sidibear likes this.
  5. doushkaAudi
    Mines not connected yet any pics?.
  6. sidibear
    2,320
    767
    JDP, just like mine, but the socket is hardwired to the boot aux socket feed.
    DR380 also. Great cam, had to clean the lens yet?
  7. doushkaAudi
    What i've seen so far suggests going through a Power Magic Pro and fuse box. As the idea for me is to record at night when the car is off does your hardwire connection work.
    No pics???!!!
  8. jdp1962
    8,183
    2,662
    I've no pics of the connection, because it's concealed under the dash. Also, I don't use the Power Magic Pro, so it's only recording when the car's in use. If you're looking for night-timer monitoring, you'll definitely need the Power Magic Pro. Why not contact forum member Cruiser89 for guidance. He sells these for a living (he may even have sold you yours, heheh!).
  9. jdp1962
    8,183
    2,662
    I've no idea where my socket is hard-wired to (it was done by a professional) but I do know that it stays live until the key is pulled out rather than until the ignition is switched off. That suggests to my limited brain that it is somehow linked to the CANBUS system.
  10. Paranoid69
    Paranoid69 Member
    79
    I've got mine fitted using two piggyback fuses in he fuse box. On train currently and don't remember which I used (tested them with a meter to find a switched and a constant).
    Can take a pic in the daylight tomorrow if it helps?
  11. doushkaAudi
    Look forward to the pics Paranoid69
  12. Paranoid69
    Paranoid69 Member
    79
    Aha, yes, completely slipped my mind...
  13. Paranoid69
    Paranoid69 Member
    79
    The lower one is the yellow BAT+ (constant) and the upper the switched power.
  14. Paranoid69
    Paranoid69 Member
    79
  15. doushkaAudi
    Great paranoid69, i'll check these out and get back. Hope your Christmas was good. Cheers
