A4 2004 1.8 TQS - What size are the discs
Nutkin Nov 17, 2010
  1. Nutkin
    Nutkin Member
    830
    Need to order some and have a choice of 2
    288mm
    312mm
    The 312mm say cabriolet option. So im assuming 288mm and its raining outside so dont really want to go take a wheel off and check.
  2. Broken Byzan
    13,237
    465
    only the big engined versions got the 312s .
    288 all the way mate
  3. Nutkin
    Nutkin Member
    830
    Good just ordered all 4 corners pads and disks for 140 delivered from brakeparts after reading many glowing reviews on several forums.
  4. quattrojames
    14,050
    577
    Are we 100% sure that quattro models don't come with 312mm discs?
  5. Broken Byzan
    13,237
    465
    I spose I could double check etka etc if you like ?, but i am 99.9% on it. It's the larger engined ones that get them, 2.5Tdi s etc etc
  6. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    i second quattrojames ( hi mate, been a while ) as far as i was aware the quatts had the bigger discs for the extra weight etc etc
  7. Broken Byzan
    13,237
    465
    B5's deffo don't
    I will check and start making my humble pie, in case i need to eat it,lol
  8. Nutkin
    Nutkin Member
    830
    acording to the shop on cabs have the 312mm discs, and also it said the 288 were the ones with the pads with wear sensors and i defo have wear sensors.
    What do i need as regards to tools? Someone said something about an Allen bolt head for the caliper removal?
    Not sure i have one of these someone confirm sizes?
  9. Broken Byzan
    13,237
    465
    The PR code is
    PR 1Lt and 1LF for 312mm discs, if those codes show in your service book etc, i am pie munching
    PR 1LZ,1LB and 1LF are 288's
    GULP!!!
  10. Nutkin
    Nutkin Member
    830
    eugh* goes to find his book*
  11. 1wheelonly
    2,385
    111
    lmfao, if youve already made it byz, if im wrong ill pop over and just eat yours, save me makin one lol.
    as for the above comment on the 288mm one having the sensors, i have a cab with the 312mm disc which also have the sensors on them.
    you will need a 7mm alan key ( which you DONT get in a set ) you only get a 5mm, 6mm and a 8mm, no 7!!!
  12. Nutkin
    Nutkin Member
    830
    Dam you I have 1LT
  13. Nutkin
    Nutkin Member
    830
    Im assuming its just written amoungst all the codes on the sticker on ym service book.
  14. 1wheelonly
    2,385
    111
    result, at least you can order the correct ones and not have the hassel of removing the old ones and then find out !!
    and byzan can now dig into his pie !!! lmfao
  15. Broken Byzan
    13,237
    465
  16. Nutkin
    Nutkin Member
    830
    I'VE ALREADY ORDERED THE WRONG ONES DAMMIT!!!!
    I want a slice of that pie.
  17. Broken Byzan
    13,237
    465
    :blush::blush::blush::blush:
  18. Nutkin
    Nutkin Member
    830
    This shall not be forgotten... I demand Satisfaction.
  19. quattrojames
    14,050
    577
    I'm just sorry I didn't post this 11 minutes earlier!
    Nutkin I'm sure if you ring them first thing you can get this order amended at no cost to you.
  20. Nutkin
    Nutkin Member
    830
    I wont be able to phone them in the morning as ill be traveling to south wales with my duelling pistols!
  21. Broken Byzan
    13,237
    465
    its ok i won't be going anywhere, my A4 is broken as always.
  22. Nutkin
    Nutkin Member
    830
    All I can say is I want some of that pie!!!
  23. Broken Byzan
    13,237
    465
    what can i say, i am human, and i error'd.
    SORRY !!
    I don't suppose it matters it was meant with the best intentions to help. My information was incorrect as I too was told the same as you ( Cabs 312 and larger engines etc) when i was doing the 312 conversion many moons ago.
    I will be more careful to not post withot irrefutable evidence from now on.
  24. Nutkin
    Nutkin Member
    830
    Pfft its fine :p Im sure it will sort itself out i'm just fed up with all the beeping and lights on the dash. got a sidelight bulb out and the air bag indicators on due to passenger seat airbag, not sure what to do about that one.
  25. 1wheelonly
    2,385
    111
    dont be daft byz, were all here to help ! we dont all get it right all the time, i wasnt 100%, was only voicing my opinion, i was more than ready to delv into that pie myself !
  26. Nutkin
    Nutkin Member
    830
    Its fine no harm done tbf only 60 quid on fronts and im sure theyll swap it tomoz
  27. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    Yep, 312's on my convertible
  28. quattrojames
    14,050
    577
    If not then I'm sure Mark will buy them....
  29. Broken Byzan
    13,237
    465
    Yeah, why not...LOL
    Will work well with my RS4 Calipers.....he he he
  30. Avant4me
    Avant4me The're Graphite not black!!
    257
    I am surprised by this as is did lots of research when looking into the 312 upgrade, didn't do it in the end as i couldn't find second hand carriers and wasn't prepared to buy new. Even EBC themselves say that all the 1.8 and 1.9 engines use 288mm discs.
  31. Broken Byzan
    13,237
    465
    Yup that was my info too..
    I hope Nutkin has sorted it now.
  32. Higgsy
    Higgsy Hard To Spin
    96
    i think ive got 312mms on my 190 qTS, prob no help but thats what it says :)
  33. Nutkin
    Nutkin Member
    830
    Order came today, more than happy. The guy on the phone was extremely helpful and just canceled one order and made a new one with me there and then.
    Brakes, brake discs, brake pads, brake calipers - Brakes International Shop
    Bits came today and the front pads are mintex oem, disks are oem packed too. Cheap as chips and more than worth it. better than no name ebay **** imo
