A4 2.8 30v Timing Belt Change
TinTin Sep 27, 2013
  1. TinTin
    TinTin New Member
    I've got a coolant leak which i think is coming from the either the water pump or thermostat housing (until i get the car up on ramps i can't get a good look at where its starting).
    So from reading on here that i have to get the belt off to change the both or either of these i wondered what everyone advised should be changed once its in bits.
    Belt
    Tensioner
    Thermostat and gasket
    Water Pump (possibly if its leaking or is it worth doing anyway?)
    ...anything else i should do whilst i'm there?
  2. shaz8389
    shaz8389 Member
    43
    Do the water pump anyway, you DON'T want to have to do that job twice.
  3. aragorn
    18,491
    855
    Water pump is a no brainer for the reasons in your post.
    Remember you will need the proper locking tool to fit the belt, and get the full kit that replaces everything.
