David280585
my a4 has never started great but always fired on 5th turn, now its spinning over 30 seconds before it fires up with a cough and loads of smoke
checked intank pump by powereing fuse 28------- all ok
replaced cooland temp----------------all ok
checked power to glows------------all ok
new diesel filter-------------------------all ok
checked cams for wear all seem ok
code read----------------------------no codes except egr recirc due to blanking plate
its a 2.5tdi 163 cab manual
no im at wittsend with the thing, the car always has had a bad vibration under acceleration like 2 cv joints are gone,also driving steady about 1500-1900rpm it stutters and holds back and when you accelerate it on boost its perfect
could it be a dualmass?
pump timing? can i adjust this myself manually or is it vcds only
pump issue?
anyone encountered similar
pump issue?
