a4 2.5tdi same engine as a6 2.5tdi help pls?????????????
David280585 Apr 27, 2010
  1. David280585
    David280585 Member
    107
    my a4 2.5tdi cab bdg engine has destroyed itself eg cams broke valves etc,it is the roller rocker engine on a 53 reg 163bhp version,
    i have located a 2.5tdi a6 allroad engine ake,are the basic engines the same?and will it fit my car and is £1500 a bit steep? i can easily source 2.5tdi non roller rocker engines but the later 2.5s are hard to find
    many thanks guys:icon_thumright:
  2. swine
    swine Member
    116
    ake is the early engine, with the chocolate cams and fragile rocker levers, best stay clear imho. as far as i know same engine bar the top end, and yes used in a4 as well as a6 and a8.
  3. David280585
    David280585 Member
    107
    thanks for the reply mine has apparently the lobes have broke from the cams and snapped rockers and mine is the later engine,anyone know what engine coded engines will ffit as a bdg is seemingly hard to get hold of many thanks
  4. adamss24
    adamss24 Well-Known Member
    4,584
    407
    I reckon the early AKE/AFB/AKN engines are much better than the later ones with cam roller followers ! On the early ones, in the event of cambelt breaks, the valves will hit the pistons and the weakest link-the cast rocker arms- will shatter thus protecting the valves from taking the full blow from the piston. The spring will close the valve and no further damage occurs. On later type, everything will mash-up and will cost thousands to put right. The wear on the early type is accelerated by the impropper oil grade used and has nothing to do with the cams but maybe the poor lubrication. Every early one that i've rebuilt after a cambelt failure had 2-4 bent valves even when it occured at high motorway speeds. I did not have the chance to rebuild a later one but-finger crossed-i will soon !
  5. swine
    swine Member
    116
    thats a good point, but i thought they replaced that old system because they wer too fragile and used to end up in the sump for no apparent reason
  6. David280585
    David280585 Member
    107
    unsure guys but im hoping i can get an engine of some sort to fit?
  7. quattrojames
    14,050
    578
    I've got an AKE engine in mine, my first one chewed itself up when then the timing belt idler pulley failed, so not really the 'engines fault'.
    I'm not totally sure, but I think the only difference between the 163 and 180 engines are fuel pumps/settings. Normally when you buy a replacement engine it's on an exchange basis, but as long as they are happy to supply fuel pump etc so they get yours in return it might be ok. I'm not sure how compatible the different fuel pumps are.
  8. David280585
    David280585 Member
    107
    was yours the later roller rocker engine james?
    also adamss24 says the ake are the early engine?
  9. quattrojames
    14,050
    578
    My past and present engine are both AKE, I dunno if they're early or late. My car's on an 03 plate, and that engine has been about in the A4 since 2001 and even earlier in the A6 so they can't be that early.
  10. David280585
    David280585 Member
    107
    well just bought an ake 60k mile engine so hopefully this will get me back onthe road this summer
  11. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,800
    50
    my AKE engine is running sweet at 197k miles, Motorway miles, I had my 4 cams followers and lifters changed on my one, the cams had groves in them, apart from that all is tip top,
