A4 2.5TDI QUATTRO 2000(W) AKN 150HP ENGINE BE CUSTOM TUNED
cready Oct 22, 2012
  1. cready
    cready New Member
    14
    New to the forum, i have a audi a4 2.5tdi quattro 150hp akn engine code (w) 2000
    Just wondering if this car can be custom tuned on a rolling road or does it need a chip soldering to the ecu?
    Thanks in advance
  2. adamss24
    adamss24 Well-Known Member
    4,584
    406
    If it has a EDC15 then it's flashable trough the OBD port. Early b5 with the AFN engine needed chip removal as they were 1 time only ! If you take off your ECU look at the connectors: if 2 large ones then it's flashable trough obd if 3 smaller ones then it's not !
  3. diffas
    diffas Member
    152
    23
    AFB/AKN have msa15 ecu instead edc15 and therefore soldering work needs to be done.
  4. cready
    cready New Member
    14
    Does that mean it cannot be custom tuned! with only a standard chip? Only i have a 3.0tdi turbo on it and bigger nozzles going on reason for custom tune as a normal chip will not be correct as far as i`m aware. I don`t know if the ecu is interchangable on these as AKE off a 2001 tdi 180 can be custom tuned i think.
  5. adamss24
    4,584
    406
    AKE does not work unless you replace the AKE pump and the dash + engine wiring loom. Few bits are different but they will swap over. Do you still want to sell the nozzles and the aditional bits ? Drop me a pm or give me a ring if you need to talk, interested in a few bits and bobs you have ! Regards,
    Chris- 07789912128.
  6. cready
    cready New Member
    14
    I was originally going to sell these parts as i blow the engine up due to oil feed burst and losing all oil, i am in process of getting another engine and starting again basically but don`t know about getting the custom tune side of things.
  7. adamss24
    4,584
    406
    Ok then, if you stll thinking of selling the bits then let me know... Good luck finding someone good enough to map the car for the hardware changes, you will experience iddle shudder from the race 683 nozzles and smoke before the turbo spool ! I have a remap by Celtic Tuning but not too happy to be honest and the above issues are still present. AKN ecu is not obd flashable...
  8. cready
    cready New Member
    14
    Sedoxperformance, have heard some good things about these for custom tune!!
  9. cready
    cready New Member
    14
    Just a thought....if i were to replace the ecu from a 2001/2002 audi a4 AKN 150hp model!! Would that work as far as custom tune is concerned for the car?
  10. adamss24
    4,584
    406
    You will need the ECU, dash + wiring loom and injector pump. You also need the ECU wiring loom and some bits are different as well. The b6/c5 AKE had a mild revision so it won't work with the old pump EDC + later pumps had an extra immobiliser built in which needs codding to the ECU... Easier to have a custom map modded with an emulator and your ECU socketed, that way you would limit trial and error.
  11. diffas
    diffas Member
    152
    23
    It's still full custom tunable. You just need to do some little soldering to add chip sockets to your ecu. Then it takes few minutes to change software.
  12. cready
    cready New Member
    14
    There is a company who can do a custom chip to the standard ecu with the turbo and nozzle upgrade but don`t know how good of a job it will be!!
  13. Broken Byzan
    13,237
    465
    Who are they? Maybe someone can vouch for them
  14. cready
    cready New Member
    14
    Celtictuning
  15. cready
    cready New Member
    14
    I have a chance of an AFB engine from year 2000 to fit my car....but the engine from mine is AKN, not sure if these engines are interchangable!!! Heard somewhere they are but dont know how true that is.
    Obviously both are 2.5tdi quattro`s but dont`t wont to swop it over and find it wont start
