Yes the nozzle.No do not start it it will chuck diesel everyhere and air lock
when you say nipple do you mean the nozzle at the bottom of the injector?
Hi Frank, thanks once again.The nozzle will unscrew from the injector, beware - the needle valve is under pressure from a spring in the body of the injector - something like this...
You'll have to make sure all the bits from the original injector get transferred to the new one - it is the internals including the needle valve that determine the characteristics of the nozzle.
I've never opened mine but there was several threads in one of the diesel forum posts talking about the nozzles and adjusting needles for more power etc.
Frank
I thought your original problem was the needle lift sensor? The needle valve is right at the tip of the nozzle held in by a spring and is purely mechanical. It could be that this also has wear but unless it's inspected by a diesel infection specialist then you'll never know.
As Darren has confirmed the nozzle from your new injector is the wrong one then I'd say the best course of action would be to swap the nozzle from the original injector to your new one and give it a shot.
In the catalog its lists them as Bosch and for the 2.5v6 but i cant find any info on the slightly different numbers, you could always take a good one out and put it in that cylinder , then scan and see if the fault has cleared on that cylinder ?
I found that very same injector brand new from europe for 153 euros.
fuel return valve ontop of the filter body , dont panic you can buy that bit from audi or any good parts place and there cheap.
Ahaaa the last number is the nozzle ,( the first number is the main injector body bosch number) so it looks like the replacement one has a different nozzle to the original.
Thanks Frank it was your post that pointed me to the nozzle difference.
Hi Frank,I don't remember having to take the doors off to get to the injectors
Try ebay for the valve - some about £16 new, cheaper if you want someone's cast-off.
Alternatively try a VW dealership or TPS (Trade Parts Specialist) with the part number from yours as they could well be cheaper.
I have a spare injector at home, I'll whip the nozzle off tonight and send you some photos of the internals so you know what's under there if you think that'll help.
Frank
To be honest I only looked at the audi part number, the car my replacements came off had the same engine code and the same Audi part number so I knew they were from a 180bhp car.
With the number of needle lift issues that crop up I would be surprised if the sensor in your new injector outlived the mechanical parts of the injector so you are probably safe cleaning out the port and fitting it with a new crush washer. Fingers crossed it's all good after that.
If it does still run badly after then put VCDS on it and check engine groups 13 & 14 to find out what the injectors are flowing fuel wise.
Good luck, Frank.
VCDS is legitI'm pretty much a novice too so here's to blind leading the blind...
Think it's group 0, then select basic settings then bottom right should be TDi timing graph. Others have said it only works on group 4, so try them both.
Engine has to be over 85 degrees for it to be accurate. Is your VCDS a registered version?
